Author Subject: Light on Windscreen!?
kit
Did a search and couldn't find anything similar?
Basically, I have only just noticed when I got out of the car to de ice the windscreen at night. Sometimes it happens and stays lit, other times I turn the ignition off and back on again and the light has gone or has dipped.
It is basically shining through where the rear view mirror is connected. I have circled it on a picture of my 6.
Any help appreciated.
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 5th Jan 2010 at 17:00
gazzerdaman
Its the rain sensitive wipers
Gary
Cherry Red GTi 6
Posted 5th Jan 2010 at 16:59
kit
Surely the light shouldn't be on? I've never noticed it before?
Posted 5th Jan 2010 at 17:01
gazzerdaman
Yes, it's the light that allows it to judge how much water is on the screen.
The light is reflected/refracted to another sensor in the unit.
The light will be on whenever the wipers are set to intermittent.
Gary
Cherry Red GTi 6
Posted 5th Jan 2010 at 17:10
kit
Ah, I see. Thanks very much for the info mate Smile
Posted 5th Jan 2010 at 17:11
cabbymeg
The reason you've maybe not noticed it is because it resets everytime you turn the ignition off. So, if it's set to auto and you turn off/on the car it will no longer be active.
Posted 5th Jan 2010 at 19:45
spitfire
Are there supposed to be two lights on the sensor, one either side?
Only my auto wipers don't seem to be working as well as they did, but I have noticed that there is only a light on the drivers side.
If someone knows or could check that would be great!
If you aint first, your last!
Posted 5th Jan 2010 at 22:23
kit
Dave, mine has two, one either side. It's like a lit up rectangle.
Posted 6th Jan 2010 at 02:23
spitfire
Cheers KIT mate, that's what I thought, I have to get another one!
How you getting on with work?
Posted 6th Jan 2010 at 02:41
