Author Subject: Speedo cuts out sometimes
justinaccurate
Ive read a few threads using the search about this being VSS or earth points but dont know if this applies to me as my Rev counter is fine
Sometimes the speedo drops to 0 for about a minute. It only seems to happen as the car is warming up and the rev counter is fine. During this time the odometer does not go up Shifty Wink
I have an earthing kit on the car so cant see it being earth related so VSS?
I found a part number for the VSS but havent found any pics of where it lives or how to fit it. Would it be something that needs a clean or better to just buy a replacement? Is it an easy job and do I have to drain the gearbox to do it?
Posted 5th Jan 2010 at 01:53
gazzerdaman
Mine did this last week, was driving along and next time I glanced at the speedo it had dropped to 0. Restarting the car seemed to cure it and it hasn't done it since *touch wood*.
IIRC you don't have to drain the gearbox oil.
That ebay one sounds like a P1 style, which operated a cable driven speedo but also fed an electrical signal to the ecu. No ebay here (work)
Gary
Cherry Red GTi 6
Posted 5th Jan 2010 at 13:57
stebro-gti-6
had the same thing on mine but i was kucky as i had a saxo vtr one in my shed put that in all working fine now.
& yes the speed is the same as i have been behined frends cars & got them to beep there horns at 20-30-& so on
China Blue on Black Clones
Posted 5th Jan 2010 at 14:21
justinaccurate
Mine did it once in november, then nothing again till now. Still doesnt do it very often, but enough to annoy me Laugh
Posted 5th Jan 2010 at 16:06
justinaccurate
Might be the wrong part number I was looking at. Damn servicebox! Welshpug said in the wanted thread it's 616070, which is about 41 quid with VAT from Peugeot.
Posted 5th Jan 2010 at 18:26
Might be worth checking out the wiring to it first and the plug to make sure its got a decent connection. Could just be corrosion as they are getting on a bit now.
Posted 5th Jan 2010 at 18:30
justinaccurate
Fair point mate. I had a similar issue with the brown temp sensor just needing re-plugging Smile
Posted 5th Jan 2010 at 18:34
fletch
Track Head
The connector should be sitting nicely in a protective bag down by the driveshaft but sometimes they get grimy and the wiring can give, try cleaning it up first.
Posted 5th Jan 2010 at 19:38
tvrfan007
Bumping this thread instead of starting my own, and thought the search brought up a good thread with this one.
My HDi has been doing this quite infrequently for a while, usually only dies for a few seconds before coming back but had it do it for over a minute before. Now my brother's newly acquired HDi is doing the same so i better fix it on both.
Did anyone find that the plug was corroded? I don't remember it being bagged up when i stripped a HDi for spares last year.
Is the speed sensor the same as above for the HDi?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 15th Mar 2010 at 00:47
justinaccurate
I still havent got round to this but it is still a problem. I bought the part from ebay for 25 quid.
I recently found the brake light switch was buggered so fixed that this weekend instead of looking at the VSS - maybe next weekend Whistle.
Posted 15th Mar 2010 at 02:48
i have this problem, but..
it only does it at one spot on the M60, nowhere else.. ever.. i can drive it directly to the spot where it will do it, and true to my word it does it there and then between one junction and only there.. Blink
Posted 15th Mar 2010 at 04:54
justinaccurate
Do you also find the clock jumps forward an hour and you suddenly have a sharp pain in your anus? That will be the alien abductions Thumbs up Alien
Posted 15th Mar 2010 at 18:49
