Author Subject: Cooling fans on P1 S16
ballys16
Dear All,
I did search, but S16s are not really covered.
So.
Seems my fans will not come on at low speed (97C) only at high speed (107C).
The AC switch also does not switch on the low speed fans, although the compressor does engage (clicks).
Not sure though if the AC should turn on the fans at temps like -8C.
On an S16, where is the GTIs "brown" plug?
Any ideas on what to check?
Swapped the relays but no change in operation.
XSi 8V -> S16
Posted 5th Jan 2010 at 00:16
ballys16
ballys16 wrote:
Dear All,
So.
OK, did some keyhole surgery to get to the connector.
Pulled it off, and the left vent came on only, but that at full speed.
Plugged it back, and the vent stopped like right away.
XSi 8V -> S16
Posted 5th Jan 2010 at 00:48
sounds like you either have a dead relay or a dead fan Smile
Posted 5th Jan 2010 at 00:51
ballys16
Knowing me, it will be the vent Sad
XSi 8V -> S16
Posted 5th Jan 2010 at 00:53
ballys16
More troubleshooting:
Relays OK (swapped them over to no avail)
Fuses OK (inspected one by one)
So its 99% the vent.
Can those be swapped one by one or the whole frame + 2 vents must come out and be swapped altogether?
XSi 8V -> S16
Posted 5th Jan 2010 at 02:01
saveloy
They can be changed individually. But they are a b*tch to change. The 3 bolts do not have captive nuts, so prepare to cut your hands to shreds.
Also, they are a Pug only part at about
Posted 5th Jan 2010 at 04:13
razzario
my s16 only ever has the fan kick in at around 90 ish... its never ever got any hotter
Posted 5th Jan 2010 at 04:20
ballys16
XSi 8V -> S16
Posted 5th Jan 2010 at 12:55
ballys16
Wish I could say that - but I suppose northern parts of England might be cooler even in the summer Smile
As said, summer here usually gets to 35-40C, winters often see -15-20C...
XSi 8V -> S16
Posted 5th Jan 2010 at 12:58
