Author Subject: Air filter question
phil19gti
Can anyone help me regarding a pipe on the air filter body?
I'll try and explain this without a photo. If you look down at the filter body, it has two pipes, one which is the 90 degree bend one which goes to the throttle body and another pipe, which comes off the body.
Mine doesn't appear to have this second pipe and instead has tape over the end.
Where does this other pipe go to and is it important?
Thanks.
2006 Performance Blue Mondeo ST TDCI
1999 Black 306 Rallye
1991 Lazer Green 205 1.9 GTi
2003 Blue Focus RS
1999 White 306 Rallye
1992 Red 205 1.9 GTi
1988 Red 205 1.6 GTi
Posted 4th Jan 2010 at 19:04
mullybaby
Its supposed to go the ICV, (idle control valve), i f you have a small filter over your valve inlet then you don't need this, but if not then you engine could be breathing unfiltered air on idle.
Posted 4th Jan 2010 at 19:24
phil19gti
No, I think you're getting mixed up by my poor description. I mean on the metal air filter body, there's two pipes that are supposed to come off that.
- One is the 90 degree pipe which goes to the throttle body pipe.
- The other one, on mine just has tape, and no pipe.
2003 Blue Focus RS
Posted 4th Jan 2010 at 19:41
mullybaby
aah I gotcha Wink
The other pipe should go up to the slam panel as a ram-intake - could do with getting a cold air feed to it if yours is missing
Posted 4th Jan 2010 at 19:44
phil19gti
Just found this photo:
The bit I need is the bit on the right at right angles to the vertical pipe. Where does it attach to?
2003 Blue Focus RS
Posted 4th Jan 2010 at 19:49
mullybaby
Just had a quick think, If this is taped up then your inlet is air tight? ie, no power?
*edit- at work so can't see your pic
Posted 4th Jan 2010 at 19:48
phil19gti
There's the vertical feed that goes to the throttle body.
Then there's the side vertical feed for the air intake, and off this at 90 degrees is a strange shaped plastic container.
What does this do?
2003 Blue Focus RS
Posted 4th Jan 2010 at 19:52
mullybaby
LOL dont think im of any use until i can see the pics
There is a small resonator that is attached to the airbox- I took this off mine- you don't need it.
Posted 4th Jan 2010 at 19:55
funscott
The item in that picture on far right is the resonator.
Join Quidco the top cash back site and earn £1.25 from my referral link (once you earn £5) http://www.quidco.com/user/571859/1838
Posted 4th Jan 2010 at 19:56
phil19gti
Is it needed?
2003 Blue Focus RS
Posted 4th Jan 2010 at 19:57
funscott
its to reduce sound. isnt vital.
Posted 4th Jan 2010 at 20:00
phil19gti
So taping the opening up is adequate?
2003 Blue Focus RS
Posted 4th Jan 2010 at 20:02
funscott
yes
Posted 4th Jan 2010 at 20:07
phil19gti
Thanks lads.
2003 Blue Focus RS
Posted 4th Jan 2010 at 20:11
