Author Subject: Brembo Help!
lost4words
Hi all,
Is there anyway of telling what Brembos i have?
LOL Strange request i know lol. They ones i have look very similar to some Lotek had up for sale a while back iirc.
Any ideas?
The pads i got with them have this on them...
So my thinking is there 406 calipers? Have measured the discs tho and they seem to be 288mm? Crazy
(Sorry for poor pic quality, taken with an Iphone Ninja )
Team 'No Longer A 306 Owner'
Team 'VTEC'
Black Honda Civic 'EP3' Type R
Moonstone 306 Gti-6 - Died at 82k
Black 306 HDI - Sold 08/08/2010 at 102,229
Posted 31st Dec 2009 at 03:43
seeing as it says 406 coupe on the pads box I'd say so....
calipers look right, decent swaged end on the hose too.
288mm discs sound like C5 ones, so the right ones for a straight fit on a 306.
Posted 31st Dec 2009 at 03:45
lukejenks101
406 coupe calipers, fit straight on with 288mm discs
PS3 I.D - jenkers101
Live i.d - Lukejenks1201
Posted 31st Dec 2009 at 03:48
giva ya
Posted 31st Dec 2009 at 03:50
lost4words
Thought they were 406 calipers... So these should just bolt on and go? Take it ill still need to upgrade the Cyclones tho?
Team 'VTEC'
Posted 31st Dec 2009 at 03:52
Rich E Forum Admin
Correct, they won't fit with cyclones. There's no issue with the disc and caliper height clearance but you need about 20mm more spoke clearance than cyclones give.
Posted 31st Dec 2009 at 04:17
lost4words
Damn such small fractions make such a differance eh?
Will these be suitable (with good discs/pads) for possible high boost? Or will another upgrade need to be made?
Team 'VTEC'
Posted 31st Dec 2009 at 04:27
lotek
they wil be fine for high boost, by the look of them they will squeel like fook. il take the discs and pads off ya if your selling though? Whistle
Posted 31st Dec 2009 at 06:07
lukejenks101
Whats the difference between the xantia discs and c5 discs?
Posted 31st Dec 2009 at 06:11
lotek
nothing
Posted 31st Dec 2009 at 07:15
what Lotek said, same part number.
Posted 31st Dec 2009 at 15:26
lukejenks101
Oh I just checked on citreon service box and they were different part numbers but same size's
Posted 31st Dec 2009 at 16:36
lukejenks101
How about 207gti discs?
They're 302x26, would they need a bracket made up?
Does a bracket need to be made for 406 discs?
Posted 31st Dec 2009 at 16:49
same part number if you look at mintex etc Wink Citroen and Peugeot are doing that fecking annoying thing of changing one silly digit to confuse things.
lukejenks101
Oh LOL
So same bit just different part number Roll eyes
What about the above ^^
Posted 31st Dec 2009 at 16:51
don't think they'll fit as they're too large a diameter, as well as being too narrow.
didn't get a chance to check properly when I fitted Adam's brembos, but I do believe the lugs on a 405/6 hub are further out by about 7mm, hence the use of a smaller diameter disc.
no brackets required to use the 406 caliper as they are a lug fitment not radial like the renfault brembo and wilwood calipers.
Posted 31st Dec 2009 at 17:11
lukejenks101
I already have the 406 brembos with xantia discs on mine, was just wondering if brackets would be needed for those Smile
Posted 31st Dec 2009 at 17:13
Huh?
Posted 31st Dec 2009 at 17:14
lukejenks101
For 406 discs LOL
they don't fit, very wrong offset.
standard 406 v6 disc is 305 x 28, and only 28mm tall, i.e pretty much zero offset.
c5/xantia disc is
288 x 28 and 34.2mm tall, 6mm more offset than a 406 hub+disc, and 17mm lower diameter, 8.5mm radius.
Posted 31st Dec 2009 at 17:21
Sunday...?Wink
Posted 2nd Jan 2010 at 01:41
good thinkings batman!!
Posted 2nd Jan 2010 at 01:47
no probs rob
Posted 2nd Jan 2010 at 02:12
