Author Subject: Wandering
astormatt
Alrite i am not sure its in the right section but, when i am driving along usually at speeds below 40mph you can notice slightly that the car can wander about.
Its not like its following the road surface bumps if that makes sense?
Since i have had it, it has had an MOT and been in for a service and nothing has ever been said about anything being loose or wearing out?
It is kind of like when i had my old Escort and replaced the 13" steels with 17" alloys.
I would have thought that i would be something to do with the steering rather than suspension but any kind of suggestions would be good.
Cheers Matt
Posted 30th Dec 2009 at 06:35
SteviePut
P bushes could be a good startSmile
Posted 30th Dec 2009 at 12:57
mr swampy s16
**BAD SELLER**
Was the track rod ends when my 309 did this
Posted 30th Dec 2009 at 13:15
gti6-ginge
ball joints also cause this. how many miles have you done as the following parts that people have listed can be worn but not so any signs of play.
MY CAR WAS BUILT ON 17/03/2000 THATS A FRIDAY OH NO
Posted 30th Dec 2009 at 16:20
Track rod ends
Balljoint
P bush
Worn beam bearings
Beam mounts
Front top mount bearings
Big tyre pressure difference
Tired dampers
Posted 30th Dec 2009 at 17:05
sacko_gti6
Echo the above.. and also check the front wishbone bolt Smile
Build Date - 30 September 1997 - Tuesday's car..is full of pace? Wink
Posted 30th Dec 2009 at 17:21
astormatt
Cheers for all your replies lads, its going in for a service in 2 weeks so i will get them to check all the things that have been mentioned Thumbs up
Cheers Matt
Posted 31st Dec 2009 at 15:56
anth
Mine has started doing this since i changed some wheels over- Tyre pressures are OK and all the forward suspension has been done.
Probably track rod ends caused by the car being all over the place on the ice i guess.
Posted 31st Dec 2009 at 16:49
webster
I believe Carl showed me you can check your pbushes by holding the wheel with two hands and attemping to move it towards front then back of car.
What you're describing sounds like Pbushes to me, I had the same problem.
cress87 wrote:
I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past.
Posted 31st Dec 2009 at 16:58
astormatt
Cheers mate, will check that the weekend.
Posted 31st Dec 2009 at 20:57
