Author Subject: head gasket change ????
spaniel
i am in the middle of changing my head gasket at the moment and i just got a few things i wanna check. first is what torgue setting do i need to set the bolts to and also how many miles do i need to run it in for and what is the max speed/revs i should go to, i have got to do a 600 mile round trip a fews days after and it is mainly motor way. any advise would be great (i don't wanna have to do this job again)
Posted 29th Dec 2009 at 22:51
no need to run it in with just a new gasket, haynes manual has the torque settings for most things.
Posted 29th Dec 2009 at 22:56
denwar
bolts are as follows.. 1st time 35nm, 2nd time 70nm 3rd time 160 degrees. sorted.
denwar
Posted 29th Dec 2009 at 23:39
denwar
if its a digital torx wrench u are using, then after you have turned the bolts 160 degrees, it usually reads abot 122nm- 127 nm, if its not digital, then turn them 180degrees and leave it at that,just done mine with a triple layer steel gasket, and its spot on.
denwar
Posted 29th Dec 2009 at 23:43
spaniel
cheers for that, i'm having a nother problem, i have tried to take the head off with the exhuast manifold still attached but it won't quite come out (it needs about 5mm more).
if i take the manifold off first then it will be almost impossible to fit it again with the new gasket. the only thing i can see to do is to remove the top engine mount and move the engine a bit. how has everyone else got round this??
Posted 30th Dec 2009 at 23:52
jonnie205
you wont remove the head with the manifold on without major hassle, take manifold off in the car, far easier in the long run
Posted 30th Dec 2009 at 23:57
mechanical_repairs
A complete pain in the arse mate, remove the manifold first it is the best solution, they are not that bad to do.
If you drop the engine mount be carefull of the inner cv joint getting crushed between the sump and subframe.
Carl
Posted 30th Dec 2009 at 23:58
gti6-ginge
undo the manifold bolts and leave it attached to the front pipe/cat and leave it in the engine bay. remove the inlet maifold and then lift the cylinder head off. clean up the head and block face replace the head gasket. refit the head then refit the mainfolds. thats how i did my mates rallye and had no trouble removing or refiting the head or manifolds
MY CAR WAS BUILT ON 17/03/2000 THATS A FRIDAY OH NO
Posted 30th Dec 2009 at 23:59
spaniel
i got it out by removing the engine mount and pulling it forward. it was definately easier than taking the manilfod off while on the car
Posted 31st Dec 2009 at 21:49
I did it this way in 2004 as I was advised to do it on this forum. It was easier when the car was on axle stands but I nicked a driveshaft CV boot with the right front suspension arm. I fixed it with a blob of silicone and it's been fine since.
Posted 2nd Jan 2010 at 03:31
mechanical_repairs
Just wait till you have to put the bugger back in. I have done a few this way but it was serious hard work compared.
Carl
Posted 2nd Jan 2010 at 01:47
Carl
I know that now Doh but I managed it with my brother.
Posted 2nd Jan 2010 at 03:33
paulchin
Now the head is off, surely the best thing would be to remove the exhaust manifold, re-attach it to the cat, then re-fit the head without?
Sort of associated question - is there room to remove the 6 manifold from underneath the car (obviously without removing the head!)? I kind of assume so, but space looks pretty tight in there and the manifold is not small!
Posted 4th Jan 2010 at 17:28
I think you would need to drop the subframe.
Posted 4th Jan 2010 at 19:30
