Team Diesel
| Author | Subject: Air con removal |
cornish_pug
Regular Location: Marazion Registered: 18 Dec 2009 Posts: 368 Status: Offline |
My air con hasn't worked since i've had the car, about 3 months. I'm looking 2 remove it, Is it an easy task 2 remove the whole air con system, and wot needs 2 be done? ________________________________________ Team Diesel |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
Get a Rallye alternator belt setup and remove any pipes, condenser, etc.________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
ablister
Senior User Location: fife Registered: 30 Oct 2005 Posts: 522 Status: Offline |
easy to see what to do but hard to do it if you get what i mean. Pipes can be tricky to remove and quite fiddly to remove some of the bits + bobs________________________________________ 306 rallye, Richard Longman enginerc10gt |
denwar
Regular Location: falkirk Registered: 08 Dec 2008 Posts: 287 Status: Offline |
rallye belt does not work, its about 30 mil too short, tried it on mine as i did away with aircon when engine was out, ended up keeping the compressor and using my original belt.________________________________________ denwar |
denwar wrote: rallye belt does not work, its about 30 mil too short, tried it on mine as i did away with aircon when engine was out, ended up keeping the compressor and using my original belt. You need the Rallye alternator belt setup, i.e. the belt tensioner, pulleys, etc and then use the Rallye belt. ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
denwar
thatl explain why mine didnt work then......siimples________________________________________ denwar |
turbowagon
Regular Location: wellington Registered: 07 Mar 2008 Posts: 371 Status: Offline |
or 2.0 xsi set up works too ive got that on mine________________________________________ slowest project car ever.com |
fozzy_255
Senior User Location: portsmouth/Folkestone Registered: 30 Dec 2007 Posts: 677 Status: Offline |
Im taking the air con off my xsi ph3 , the rallye set up will fit this engine too right as same block? |
