Author Subject: Finally been beaten by nature
cwspellowe
Can't believe how f*cking cold it was last night, even with antifreeze the coolant seems to have frozen.
Can't seem to understand what's happened though, the car was overheating to the point the red lights came one, and both fans were on, but when i took off the radiator cap and the rad top hose it wasn't even slushy?
Could something be frozen further down the radiator? Or buggered thermostat?
Bit worried about the block too if it's managed to freeze...
Bye bye Sundance Kid Sad
Posted 24th Dec 2009 at 17:10
chris with a pug
Is the waterpump working? maybe the fins have come off.
Or could be the thermosat. is the rad cold? if the stat f*cked it should be cold
Posted 24th Dec 2009 at 18:04
cwspellowe
the rad got hot, as did all the hoses, which suggests there's circulation.
I know there's no airlocks too, system was bled when I was looking at the matrix
Posted 24th Dec 2009 at 20:05
allesclar
is it fully circulating though? i would double check as if its fully circulating then surely the engine wouldnt over-heat?
Team allesclar ®
Posted 24th Dec 2009 at 20:15
cwspellowe
that was lucky, turns out the coolant in it was just rusty water.
flushed the system with hot water followed by fresh coolant, working fine now.
Posted 24th Dec 2009 at 22:38
