displaying posts 1 to 25 of 67
Pages (3): [1] 2 3
Author Subject: Citroen ZX 16v
my911gt2
my new rebuilt zx 16v engine ,
cat cams
block decked
3rd valve angle cut
lighted fly wheel
balanced bottom end
gti6 box
ported and gas flowed head
fully rebuilt , every gasket and seal new
new pullys
set up for 45 weber carbs
alloy sum fitted
forged pistons and rods
new lifters
new coil packs
mocal oil cooler kit
waiting for -
new coolant hoses
alloy bottom pully
final engine clean and prep ,
new dip stick
i would like to know your thoughts , i have spent alot of time doing this engine for my citroen lol ,
thanks
Citroen ZX 16V ,
Posted 24th Dec 2009 at 02:31
my911gt2
pics
my911gt2 has attached the following image:
Citroen ZX 16V ,
Posted 24th Dec 2009 at 02:32
my911gt2
pic
Citroen ZX 16V ,
Posted 24th Dec 2009 at 02:34
my911gt2
pic
Citroen ZX 16V ,
Posted 24th Dec 2009 at 02:35
my911gt2
pic
Citroen ZX 16V ,
Posted 24th Dec 2009 at 02:36
my911gt2
pic
Citroen ZX 16V ,
Posted 24th Dec 2009 at 02:37
matty_rallye
Looks tidy, nice spec. Have you done the work yourself?
2.1 16v 306 Rallye.
my911gt2
yeh all work has been done by my self apart from the decking and boring e,c,t lol and gas flowing
but all the rebuild work e,c,t done by me and my misses
Citroen ZX 16V ,
Posted 24th Dec 2009 at 02:38
ballys16
my911gt2 wrote:
pic
Nice looking engine and specs!
BTW, is that your forklift?
XSi 8V -> S16
Posted 24th Dec 2009 at 02:42
my911gt2
thanks , that one is not nope , why do you ask tho lol , that is just one that is in my unit lol , i dont own it
Citroen ZX 16V ,
Posted 24th Dec 2009 at 02:43
matty_rallye
Your misses?!
Got any pics of the car its going in?
2.1 16v 306 Rallye.
Posted 24th Dec 2009 at 02:47
mxcrazy
Why carbs? is this going to be a road motor or track hack? what about emissions with mot if its road lump, i know the power can be had with carbs, but what about drivability? surely to get the most from them you need a decent ignition set up, what yours going to run? Your not too far away from me either.
Posted 24th Dec 2009 at 02:48
my911gt2
yeh i have a few pics of the car sorted in a day or two
i am doing a total rebuild of the shell
Citroen ZX 16V ,
Posted 24th Dec 2009 at 02:50
ballys16
Would fit the profile of a man building his engine with his wife Wink
XSi 8V -> S16
Posted 24th Dec 2009 at 02:52
my911gt2
its going to be for road and also track use , as for mot , i cant see why when it is set up correctly on a roading road it wont pass even if i have to detune it for mot , and i will also remove all the engine numbers so they have to carry out a default test which is higher limits
Citroen ZX 16V ,
my911gt2
what do u mean u lost me
Citroen ZX 16V ,
Posted 24th Dec 2009 at 02:54
ballys16
Is the body also a ZX?
XSi 8V -> S16
Posted 24th Dec 2009 at 02:56
my911gt2
Your misses?!
yeh my misses she helped and did bits along the way lol which was good ment i got to build engine with no moaning lol
i got to come up to ur town to collect some tsw venoms 16"
Citroen ZX 16V ,
my911gt2
yeh its a zx 16v body
Citroen ZX 16V ,
Posted 24th Dec 2009 at 02:57
mxcrazy
Im no mot tester for sure, but i think even on the 'de-fault' test you'd struggle to get carbs through, you just dont have the part throttle fuelling control of injection. You could all ways claim that the engine is pre-cat, so more lenient on emissions side? be interesting to see how it goes.
Ive put a deposit on the 1st parts for my engine build today.
Posted 24th Dec 2009 at 03:02
my911gt2
what are you doing to yours then ?
and its a 1993 so has to have a cat fitted
and i am an MOT tester lol
Citroen ZX 16V ,
Posted 24th Dec 2009 at 03:03
ballys16
Nice body. Shame there are not many 3drs running around Sad
I dont see any ECU in your setup - OEM tuned?
As for emissions - E85 does the trick usually
Ninja
XSi 8V -> S16
Posted 24th Dec 2009 at 03:04
my911gt2
i was going to start off by using the OEM one yeh , due to cost , at a later date i will get a remapped one ,
Citroen ZX 16V ,
Posted 24th Dec 2009 at 03:06
mxcrazy
If you get a dummy receipt to show that the engine was bought, and is earlier than 1993, the MOT stations test to whatever is older, the car or the engine, that what im lead to believe anyway.
Some people wont agree with me on this, but im going 88mm stroke, 88mm bore, for 2139cc, 11.5:1 compression, reasonably stock head, just clean the ports, 3 angle seats, maybe un-shroud the valves if needed to improve low lift flow, throttle bodies, management, there will be room for big cams with the pistons im using, but i dont want to go wild, keep costs down a little, keeping a stock exhaust cam and going with a little more lift and duration on the inlet side. I dont want an engine that i have to rev the tits off to get it moving, im 'aiming' for 210 ish bhp with emphasis on drive-ability and torque.
It will probably end up costing me as much as a low boost supercharger conversion, difference being i want to have the experience of building the engine. The cams would be an area that could be improved on funds and time permitting.
Posted 24th Dec 2009 at 03:27
mxcrazy, DSrSarty on the 205 drivers forum has a similar spec engine producing over 230 bhp and about 190 lbft's with a stock exhaust cam, Peter Taylor stage 1 inlet, sandy brown/colin satchel throttle body inlet and emerald ecu.
Posted 24th Dec 2009 at 03:48
Pages (3): [1] 2 3
