Author Subject: drive shaft oil leak
anthony_p_59
while changing the coil spring this afternoon we pushed the hub down a bit too much and now there is a small oil leak coming from the driveshaft/gearbox boot. will i now have to change the oil seal if there is one? or can i just re-clip the boot in place.
done a 'search' but failed miserably.
thanks
Anthony Thumbs up
Posted 24th Dec 2009 at 01:58
jpmatrix
You have most likely damaged the oil seal while changing the coil spring most probable cause is the hub carrier swiveled out to far and the splined part of the driveshaft came into contact with the seal and damaged it. Thats what happened to me when I replaced my front dampers.
Oil seals are pennies but you going to have to remove the drive shaft compltely. Make sure when refitting the driveshaft you insert it carefully into the gearbox without the splines rubbing onto the driveshaft oil seal.
Posted 24th Dec 2009 at 16:16
just push it back in, usually just fine apart from needing to top up the oil level.
Posted 24th Dec 2009 at 16:26
anthony_p_59
thanks guys, car is in work so going to top up the oil tommorow and take it from there, Thumbs up
Posted 28th Dec 2009 at 17:30
lwgti-6
Make sure you keep an eye on it tho mate....Last thing you want is for it to go bang!..
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 28th Dec 2009 at 18:54
