Author Subject: Brake Problems HELP!
stebro-gti-6
Any one had this before?
My brakes work fine until you go to stop quickly when the car seems to sway about, mainly from the rear but at the same time front dose too,
I have had it on the brake tester at my mot station & all is well, no imbalance at all.
All my brakes look fine, when braking normal it stops as it should no pulling, but when you stamp on them & the ABS kicks in Holy MOG it
China Blue on Black Clones
Posted 21st Dec 2009 at 03:28
rear beam bushes are probably knackered, i'd also chekc front wishbone bushes.
Posted 21st Dec 2009 at 03:40
stebro-gti-6
i have done the front wishbone bushes but i have not looked at the rear beam, will have a look in the morning. Tnx
Posted 21st Dec 2009 at 03:44
Same tyres all round?
Posted 21st Dec 2009 at 03:51
Rich E Forum Admin
What condition are the dampers in?
Posted 21st Dec 2009 at 03:59
stebro-gti-6
Yes all the same & all good
Posted 21st Dec 2009 at 04:12
stebro-gti-6
fronts are new dont know on the rear's but i have two Spax shocks for the back.
i have got a New rear beam (came of a car that had only done 10 miles)it's complete with mounts but its off a 1.4 or a 1.6 i think? but the mounts will be the same, i Hope :-)
Posted 21st Dec 2009 at 04:17
birk
It will have different size arb and i think thinner torsion bars, so i wouldnt reccomend fitting it.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 21st Dec 2009 at 04:20
stebro-gti-6
i was only keeping it for the mounts & the main tube
as the bearings are new
Posted 21st Dec 2009 at 04:25
sport spec 306's have different mounts to non-sport spec.
main crossmember and trailing arms are usable though Thumbs up
Posted 21st Dec 2009 at 04:30
stebro-gti-6
dam i think i might just put the mounts on & see what it's like, just until i can get GTI 6 one's
Posted 21st Dec 2009 at 04:32
SteviePut
Fit the right ones to start with fella. What's the point in doing things twice?? Just my
Posted 21st Dec 2009 at 12:44
stebro-gti-6
have just phoned up 4 motor factors & have been told that the rear bushes are all the same part number from a 1.4 up to the GTI6,
so going to go to my mot station & ask to use there ramp for a bit as it's fcking cold outside
Posted 21st Dec 2009 at 14:23
they may well say that for cheap aftermarket bits, but if you go for original they are different, cheap aftermarket bits will be nowhere near the stiffness of o.e bushes.
uprated suspension models use -
5131 69 FLEXIBLE JOINT LEFT AV PAULSTRA - 3 DOOR SALOON WITHOUT COLOUR MARK
5131 70 RIGHT AV PAULSTRA - 3 DOOR SALOON WITHOUT COLOUR MARK
they are
Posted 21st Dec 2009 at 16:29
stebro-gti-6
they are
Posted 21st Dec 2009 at 17:04
stebro-gti-6
well i put the new rear beam mounts on today all 4 & spaX shocks New rear discs & pads STILL the same going to have it tracked up in the morning so we will see whats what
Posted 23rd Dec 2009 at 02:27
cooper666
mine had the same fault untill i fitted braided hoses and fitted the rear pads the right way with the noggin locking into caliper piston.braked straight and true untill abs kicked in not sure what of the above cured it though.
clio r27
ps3 id:cooperkloe
Posted 1st Jan 2010 at 01:33
