Author Subject: 306 2.0 8v what mods can i do to the engine to make it a hell of
madhead1987
hi im a newb to this forum, erm basically i just wanted some advice on how to make my cab faster without changing the 8v lump thats in it at the min and was wondering to turbo it what would i need to do, cheap cheap way Whistle
more power bazil!!
Posted 19th Dec 2009 at 15:00
madhead1987
and also is there a modded rocker cover for them to get rid of that sh*ty plastic cam cover /airbox as no longer need it ?? or do i lol
more power bazil!!
Posted 19th Dec 2009 at 06:47
c_j_m
1. Theres a edit post button.
2. This is a GTi6/Rallye forum.
3. Type in full and readerable sentences, with proper grammar and spelling.
4. The 8v engine is a bit crap TBH so theres not a lot really worth doing to it. Mi16/S16/GTi engine etc is a better idea, both time and cost wise.
5. Sort the handling and brakes etc. first as theres no point in power without control.
6. Wear well with it.
Posted 19th Dec 2009 at 07:04
allesclar
In fairness madhead1985, c_j_m hit it straight on the head.
The time and money spent on this, you would be far better off getting a better engine and installing that instead. Would be cheaper and quicker too by the time you have faffed around.
Also the amount of room to improve your engine is not alot at all.
This is a GTi-6/Rallye forum, doesnt mean you can't ask, but use abit of inititive. We aint gonna tell you its worth investing all your money on a low spec engine now are we Whistle
Save yourself alot of hassle, wasted money and time, sell your current car and get a 6' if you want performance that bad.
Thats what i did with my old 306 1.6 LX Thumbs up
If after all that you are still sticking to your guns, then the money would be far better spent on getting the tires done while also getting the brakes upto a good standard too Smile, but then agian the amount you would spend there, you might aswell sell your car and get a 6'.
A 6' would be better at stock than you could put into tires and brakes for the same money. anyway ill shutup now.
Team allesclar ®
Posted 19th Dec 2009 at 07:53
madhead1987
i understand that this is a gti 6 club and that i just wanted some advice on wot to do at the min, i havent got the funds for the 6 engine and had that in mind, so i just wnted some advdice ive already uprated the brakes for drilled and grooved allround and grennstuff pads and have toyo proxes allround as well . thanks neway for the replys . and sorry for spelling incoreclty im no good at spelling Wink
more power bazil!!
Posted 19th Dec 2009 at 15:02
Eric Fail there CJM on the spelling front - wtf is 'readerable'? Razz
1. Welcome to the forum.
2. Drilled and grooved discs aren't going to help you much, so save some dosh and get decent OE discs next time round.
3. Ditch the shite greenstuff and get some Ferodo DS2500 or Mintex 1144 pads instead. They actually work unlike the Greenstuff.
4. Get some GTi6 brakes on there. No idea if they will fit but someone on here will know. You might need to upgrade the master cylinder too.
5. At least refresh the standard suspension for good quality stuff. Bilstein B8 or Koni dampers and Eibach springs are a good entry level setup. You can upgrade the rear TBS and ARB to something better by using Xsara VTS ones.
6. Engine - I would personally leave it to simple breathing mods. If you start going for a new cam etc then you might as well sling in another engine.
Overall you'll gain more from better brakes and suspension than anything else. If you can make it lighter then do so. Lighter 15" 7" wide alloys can make a huge difference with good tyres. Michelin PE2s are a lot better than the proxies and last a lot longer. They also are considerably lighter and help acceleration. You can go to 195/50/15s to help save some dosh, but the speedo will over read by about 5%.
Hope this helps you a bit!
Posted 19th Dec 2009 at 23:03
dragoon
get one of the 16v engines and throw it in..
also upgrade brakes & suspension as said in the post above
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
Posted 19th Dec 2009 at 23:26
ballys16
Smile
I think I've been there Big grin
Engine performance
1 - either accept the XSi as is or
2 - swap your engine
3 - spend tons on your current powerplant to gain ~15 bhps
Well, its up to you. I went for the S16 engine swap, but TBH, it was not really worth it.
XSi 8V -> S16
Posted 19th Dec 2009 at 23:30
jcphat
The 8v engine can be cammed (1.9Gti) and you can fit a better exhaust manifold but for much improvement you need to fit a better engine.
Brakes- what you have done will make a little improvement-a lot if the old ones were shagged. GTi6 front brakes, discs,calipers and pads with braided lines will make a huge difference and are a straight fit.
The prxes are a perfectly good upgrade from budget or ditchfinders.
New shocks, O/E spec and eibach springs are well worthwhile.
Join here http://peugeot306cabrioletclub.co.uk/index.php
mechanical_repairs on here is in Leicester,has worked on and owned cabs and may have brake parts for you.
New Forum same high quality intellectual debate!
Team Zimmer™
Posted 19th Dec 2009 at 23:34
dragoon
tbh, for a basic to light tuned 2.0 8v lump, the standard 266mm brakes provide MORE than enough stopping power (with decent pads/discs mind)
so no need for the heavier gti6 setup
Team Wheelwhore
Posted 19th Dec 2009 at 23:36
stebro-gti-6
try & ask on the pug306.net fourm As this is for GTI 6 & Rallye's
China Blue on Black Clones
Posted 19th Dec 2009 at 23:47
jcphat
Not so, the cab is heavy and needs better brakes.
Team Zimmer™
Posted 19th Dec 2009 at 23:49
feno22
lmao orite reece fancy seeing u on ere its nick used to go to college with ya in nottingham ive just bust my gti-6 il do ya engine cheap Razz
fenooo
Posted 19th Dec 2009 at 23:50
dragoon
hmm, a cab... missed that, nvm what I said then!
Team Wheelwhore
Posted 19th Dec 2009 at 23:57
chrisd306
drop a 406 or 605 2litre 8v turbo in it, you can pick the engines up for about 150quid, drops straight in, my mate a joiner managed to fit his, and you can get 180 to 200bhp out them easy.
and get some gti6 brakes.
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 20th Dec 2009 at 00:47
madhead1987
sound feno how is it ? how much will? need it asap as now have mazzive oil leak have no idea where its coming from done rocker not that , checked cam shaft sensor not that only thing i think could b is head gasket done water pump as well dnt wanna take it out cant be arsed lol
more power bazil!!
Posted 24th Dec 2009 at 00:25
ballys16
Its a head job - had it with my 8V.
Head skim + gasket + bolts + belt and tensioner.
Cost was ~300 pounds.
XSi 8V -> S16
Posted 24th Dec 2009 at 02:50
madhead1987
thought it might be gna do it me self only just done the cambelt and etc. so just head of skim and gaskets ay , i was hoping it wasnt that lol
more power bazil!!
Posted 24th Dec 2009 at 22:01
ballys16
Who knows, you might be luckier... oil was coming from the right back side of my engine, mostly.
XSi 8V -> S16
Posted 25th Dec 2009 at 00:54
