Author Subject: Xu7 and xu10 cambelt compatability
allanallen
Does anyone know if a citreon xu7 cambelt kit (part no. 083156) is the same kit that the j4rs uses? Cheers folks
Facebook
Posted 18th Dec 2009 at 21:24
rallyeash
no, believe the xu7 is 133 tooth same as the xu9j4
309 3dr K20 Type R
Posted 18th Dec 2009 at 21:27
servicebox says no.
belt itself is the same 136t one.
0831 57 MOTOR KIT XU7JP4. sprung plastic tensioner
0831 67 MOTOR KIT - INJECTION XU7JP4 AND EEC 2000 DEPOLL (ENGINE) steel eccentric tensioner
0831 48 MOTOR KIT - INJECTION XU10J4R / XU10J4RS steel eccentric tnsioner
0831 71 MOTOR KIT - INJECTION XU10J4RS 137t spring plastic tensioner.
belt and front idler is the same, just the tensioner different between the kits Smile
Posted 18th Dec 2009 at 22:32
quite random this, I was sure the XU7 used the same kit as the gti6, so I checked under the 406, adn Voila!-
0831 48 MOTOR KIT - INJECTION XU7JP4 AND EEC 2000 DEPOLL (ENGINE) UNTIL RPO No. 08469 SEE A
0831 67 - INJECTION XU7JP4 AND EEC 2000 DEPOLL (ENGINE) SINCE RPO No. 08470 SEE A
chuffing random they are LOL
Posted 18th Dec 2009 at 22:49
allanallen
Bloody typical, the kit i'm looking at has the eccentric tensioner so I rekon it'll fit then.
Facebook
Posted 18th Dec 2009 at 23:39
Just noticed I didn't check your part number, Doh
I'll have a looksee now, might be one of those odities where Citroen used a different part number.
yup, bas**rds! Laugh my ass off
their 137T RS kit is 0831 72
136t RS/R kit is 0831 49 MOTOR KIT - INJECTION XU10J4RS
your 0831 56 is a 136t with eccentric tensioner for XU7's.
Posted 18th Dec 2009 at 23:56
allanallen
Seems that all the 136 kits 'should' be the same then Roll eyes
Facebook
Posted 19th Dec 2009 at 00:28
not really, the tensioner is different, the idler is the same though.
Posted 19th Dec 2009 at 00:33
allanallen
Correct, its a bloody plastic auto tensioner. I thought it was listed as an eccentric metal one? Never mind
Facebook
Posted 19th Dec 2009 at 01:46
rallyeash
on my mi16/gti6 hybrid i was running xu7 headgasket and cambelt, sure that was 133 tooth, hmm...
309 3dr K20 Type R
Posted 19th Dec 2009 at 14:59
if you use an MI16 bottom end its more likely to have been an Mi16 kit, especially with 133 t Wink
Posted 20th Dec 2009 at 05:08
