Author Subject: Heater air not hot enough?
ballys16
Hello Everyone,
With winter being quite cold here (-9C yesterday) I noticed that although the heater is working it somehow does not produce the heat I expect from it.
Its not cold, not hot, sort of mild?
Water temp is fine, no overheat, bled OK, no airlocks it seems. Also, the heater matrix does not fog the windows, nor does it leak.
The higher rpm I put the vent to the cooler the air.
Also, with higher engine RPMs the air seems to get hotter, but cools off when the car is stationary or when the cooler vents kick in.
Heater matrix on its way out? Or clogged?
Suggestions welcome.
Thanks!
PS: coolant level is normal, and it is filled with antifreeze from Pug (100%, no water added).
XSi 8V -> S16
Posted 18th Dec 2009 at 15:03
rallyestyle
What settings do you have the vents on? I think the GTI6 may have electronic control of the heaters so something there could be malfunctioning?
Just Drive It
Posted 18th Dec 2009 at 16:37
ballys16
P1 S16/XSI, but is the same as GTi6.
It is partially automatic, yes.
The electronics don't seem to malfunction for all functions work. Its only the amount of heat that I find appalling.
XSi 8V -> S16
Posted 18th Dec 2009 at 17:00
rallyestyle
I think the heat selector is a cable though right? Do you have any control over the heat? i.e. can you move it from luke warm to cold?
Just Drive It
Posted 18th Dec 2009 at 17:08
ballys16
Hm, I think its not a cable.
I can move it freely and it does change the air temp - just hot in this case is mild only. Can take off my coat, just my swimming trunks won't do Smile
XSi 8V -> S16
Posted 18th Dec 2009 at 17:46
jim01uk
If it has climate control then the heat selector is an electronic actuator.
Posted 18th Dec 2009 at 19:04
ballys16
Yes, I have an "auto" AC.
XSi 8V -> S16
Posted 18th Dec 2009 at 19:39
ballys16
Isn't there a flap that diverts air to pass through the heater matrix?
Or how does this work?
XSi 8V -> S16
Posted 19th Dec 2009 at 15:13
bobdylan_55
rev it harder it will heat up more Wink lol
or cover up part of radiator so it gets hotter.
309 GTi6-T
Posted 19th Dec 2009 at 16:05
ballys16
With ice & snow I think the revving bit is not going to work out just now Smile
As for covering the rad - coolant temp is ok according to the dial....
XSi 8V -> S16
Posted 19th Dec 2009 at 19:29
ballys16
Just experimenting.
I can get totally cold air, so the flap is working to some point.
Also, if I set the circulation to cabin, it is ~OK (windows will mist of course)
XSi 8V -> S16
Posted 19th Dec 2009 at 19:35
ballys16
Just experimenting.
Also, just checked: both hoses are hot.
The flap motor does engage, and it makes a sound when it reaches both of its limits.
Point of "engagement" is somewhere in the middle of the cold zone.
AC + inside circulation more or less made things comfy. Switching to outside air it cooled off right away.
XSi 8V -> S16
Posted 19th Dec 2009 at 23:07
mangledmetal
the auto temp sensor in the dash mucky?
Going through the gates of Hell Backwards, in a ball of flames!
I'll, save you a place!!
Posted 19th Dec 2009 at 23:21
ballys16
Where can I find that?
XSi 8V -> S16
Posted 19th Dec 2009 at 23:31
ballys16
Funny how -18C on Sunday became +16C by Friday....
Of course heat is OK for today Big grin
Still, auto temp sensor - what is it?
XSi 8V -> S16
Posted 25th Dec 2009 at 17:19
andy306gti
Does it get significantly warmer when revved/driving and gradually cooler on idle? Had a similar problem with mine, Then the heater matrix broke which I then replaced and voila constant hot air. happened to a mate of mine with an xsi as well so I think it might be quite common.
Posted 26th Dec 2009 at 01:32
dave555
have u checked the water level thats what was up with mine the other day , thats how i found out i had a leak
Posted 26th Dec 2009 at 02:10
ballys16
Exactly - hot whilst driving, cool on idle.
Will have the matrix changed in January.
Pug tech charges ~50 pounds for labour... outside "office" hours of course...
XSi 8V -> S16
Posted 26th Dec 2009 at 02:17
ballys16
Yes, checked and no air locks whatsoever, antifreeze at -30C.
Matrix to be changed shortly.
XSi 8V -> S16
Posted 26th Dec 2009 at 02:18
Sounds like heater matrix to me, I've done several of these and have to say i wouldnt be interested for
Posted 26th Dec 2009 at 05:39
ballys16
XSi 8V -> S16
Posted 26th Dec 2009 at 19:37
