paul.e.
| Author | Subject: im so confusedededededdd |
paule151
Newbie Location: tunbridge wells Registered: 30 Nov 2009 Posts: 36 Status: Offline |
keep having to push start my car to start it, it only need sayy two foot and it starts i had alternator tested charging at 14.3 and 14.28 wth headlites on full beam i dont know what it is its a pain in the arse especially now in the winter months the battery all ways seems to be flat something somewere is wrong any ideas________________________________________ paul.e. |
Welly
Forum AdminLocation: Brizzle Registered: 11 Jan 2004 Posts: 21,796 Status: Offline |
Dead battery? Knackered Starter________________________________________ Life is a lie. The only certainty of which is death. Go live and enjoy yourself. The clock is tickingVrs power!! |
cabbymeg
Regular Location: Alfreton/Derbyshite Registered: 04 Sep 2009 Posts: 323 Status: Offline |
Dead battery? Just because the alternator is charging doesn't mean the battery is holding it. Failing that, starter motor sticking maybe? Edit: Beat me to it! |
paule151
cabbymeg wrote: would a dodgy starter be killing the battery, battery is new but got it online it was good for a week or so could it still be faulty thoDead battery? Just because the alternator is charging doesn't mean the battery is holding it. Failing that, starter motor sticking maybe? Edit: Beat me to it! ________________________________________ paul.e. |
cabbymeg
It could be, what happens when you try and start it on the key? |
paule151
cabbymeg wrote: jus clicks if its been runnin for say 10 mins it starts fine but otherwise loud clicking noiseIt could be, what happens when you try and start it on the key? ________________________________________ paul.e. |
hbinky
Newbie Location: Wem Registered: 22 Jun 2009 Posts: 36 Status: Offline |
Starter would only be a possible problem, as stated, if it was sticking, if this was the case the engine wouldn't turn over, it wouldn't drain the battery if faulty. Were you having charging / starting problems before the new battery was fitted? Have you got some crazy device plugged into the cigarette lighter? |
deadbattery ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
simonjames
Seasoned Pro Location: Whitland S.Wales Registered: 23 Nov 2004 Posts: 6,219 Status: Offline |
Dead battery or bad conections on batery teminals ________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
kellaway
Regular Location: Richmond N/E Registered: 09 May 2007 Posts: 325 Status: Offline |
When you go to start from cold, turn all of the car electricals on, then try and start - if all your lights dim and the starter motor clickes then the battery is fooked, if the lights all stay bright and the starter just clicks then its starter motor time.________________________________________ Moonstone FTW |
paule151
hbinky wrote: yes was having star trouble so i replaced battery and no device in cig lighter strange lolStarter would only be a possible problem, as stated, if it was sticking, if this was the case the engine wouldn't turn over, it wouldn't drain the battery if faulty. Were you having charging / starting problems before the new battery was fitted? Have you got some crazy device plugged into the cigarette lighter? ________________________________________ paul.e. |
paule151
kellaway wrote: wen i charge battery its fine but after a few day i have to push batt keeps dying why why WHYYYYYYYYYY!! lolWhen you go to start from cold, turn all of the car electricals on, then try and start - if all your lights dim and the starter motor clickes then the battery is fooked, if the lights all stay bright and the starter just clicks then its starter motor time. ________________________________________ paul.e. |
simonjames
something is draining it thenits a prosess of disconecting things till you find whats draining it ________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
Check the battery terminals are on ok and also check the earth points, the main one on top of the gearbox can cause all kinds of issues.Check the wiring to the alternator as well. Could well be that if the battery is charging ok outside of the car. I know you've checked the voltage but even so... ________________________________________ Nothing to see here |
