Author Subject: Strange Engine Problems!
tobs
Right have a number of issues with my car at the minuite and was wondering if you guys could offer an explanation!
- Really rough idle just after starting
- After driving for a while when in neutral or with foot on the clutch the engine repeatedly revs fromm 1k to 1900 revs and drops and repeats.
- Engine carries on going after foot is taken off the throttle and then drops off very harshly after a couple seconds.
- Strangely after starting the speedo and rev counter flip around to max then back again.
Thinking it could be a problem with a sensor or a nubmer of sensors. Possibly idle control?
Any idea guys? Help is very much needed and appreciated!
Gti6 - Diablo Red - Scorpion Back Box - Cobra Alarm - 167bhp
Posted 13th Dec 2009 at 17:10
SteviePut
The idling problem sounds like the stepper motor playing up. Mine did exactly the same and a new stepper sorted it but giving it a clean may helpSmile
The speedo issue could be a your battery being on it's last legs.
Hope this helps
Posted 13th Dec 2009 at 17:21
china_306 Banned!
i have ½ an answer to one of your problems Razz, the speedo has somthing to do with the earthing points, myn does the same, however i dont know which earthing points they are! and as for your engine problems, seems the the ICV...
Posted 13th Dec 2009 at 17:23
mad_dave23
Mine used to do the 2nd and 3rd points above, so I changed the lambda and map sensor, problem solved!
Posted 14th Dec 2009 at 01:36
sentrix
I had this same problem.I disconected the sensors on and around the throtle body cleaned them reconected and its been fine ever since.
Freeman
Posted 14th Dec 2009 at 02:32
toby
A lot of the issues could be down to a bad earth, make sure your connection to the battery is tight and that the leads going from it to the gearbox and chassis are good, if you connect a jump lead from the battery to the engine does it improve things?
Make sure the positive from the battery to the fuse box is good and also from the battery via the starter to the alternator. If the ECU isn't getting enough voltage it will cause all sorts of problems.
Previous Peugeot - 2000(w)GTI-6, Me old China, Supercharged with working aircon!
Posted 15th Dec 2009 at 00:07
jaydog81
no 4: Its telling you to give it some nuts.LOL
Mine did this once and has never returned!
*jay81.
Phase 2.5/S-99
Team i live for working,Paying bills and funding my hobbies. I wish my life could be just living for a pink "I love the 6 sticker".Laugh my ass off
Posted 15th Dec 2009 at 00:33
tobs
Where's the best place to get my hands on an ICV?
Posted 16th Dec 2009 at 19:11
tobs
had a clean of the icv today and cleaned the electrical contacts (both of which didnt make a blind bit of difference) while there i came across a random plug, doesnt seem to plug into anything but runs in the same loom as the map sensor.
Can anyone shed any light on this?
http://www.youtube.com/watch?v=Hsg8AHdlKUY
Posted 21st Dec 2009 at 02:41
tobs
It's a standard loom for many models so there are plugs not used.
Posted 21st Dec 2009 at 02:49
cress87
Yup, don't worry about that plug.
Posted 21st Dec 2009 at 02:52
rufio306
my car done number 4 on your list this morning, i had left the ignition switched on for ages while i was polishing it. when i got in and turned it off and back on all the dials went the whole way round and back again, thought nothing of it but now i think it might be something fishy
Posted 21st Dec 2009 at 03:02
stegti6luvr
Really sounds like an issue with the ICV, Check it is properly plugged in and spray some wd40 into the contacts... It may be worth getting another from a breakers to rule it out Wink
Posted 21st Dec 2009 at 03:03
