Author Subject: Fog lights not working. Any ideas???
benn25
Trying to change standard fogs to aftermarket. Rewired to blue connection plug. Connected - Not working. Checked fuse - Intact. Warning Lights -On. Flicked between side, dim and full - not working. Rear fogs - working. Bulb - working. Changed wiring combination - not working. Back to what its supposed to be - still not working. Traced wire to main connection (cleaned). Still not working. Changed relays - still not working. Any ideas?????
There is also a relay missing from the fuse compartment in the engine bay. Its a grey 5 pin socket. Has this got anything to do with it? Whats it for?
Posted 12th Dec 2009 at 16:51
cooper666
both or one fog lights? ive had 2 before where the wires break inside the plug cant be seen(on the loom side not fog light side)
clio r27
ps3 id:cooperkloe
Posted 13th Dec 2009 at 01:16
allesclar
yeah it could be the plug, you have an amp meter to hand?
Team allesclar ®
Posted 13th Dec 2009 at 01:17
SteviePut
Are the aftermarket ones earthed in the same way?
Posted 13th Dec 2009 at 02:23
benn25
both lamps. yea the aftermarket ones are quite simple really. Earth tag and the H3 bulb has a connector to it already. Off to screwfix to get one me thinks. Ill come back with some results. Hopefully positive. Could connect to main beams, but don't want to suck any power away from them. I managed to connect the other 2 lamps as I have 4 on the front bumper to the adjust motor. Works a treat. Cheers chaps
Posted 13th Dec 2009 at 05:33
