displaying posts 1 to 25 of 30
Author Subject: airbag light MOT fail?
braymond
Ive put a fixed bucket in the Rallye, so the pre-tension is obviously disconncted, resulting in tedious light on dash board.
Will this light being on flag up an MOT failure??
"if its fitted it must be working" kind of affair?
Rallye-R
Nurburgring article
Posted 10th Dec 2009 at 20:27
remove bulb and all your problems suddenly go away at mot time. that is not the cure, but testers are arseholes, and will pass it
Posted 10th Dec 2009 at 20:05
braymond
Yeah, tis what i thought, but i didnt want to get involved in dash removal if i didnt have to. but if it will result in a a bit FAIL then i guess i'll have to get in there. Never taken a dash off before...is it easy?
Rallye-R
Nurburgring article
Posted 10th Dec 2009 at 20:09
not dash removal.. just undo the 3 or 4 torx bolts for the speedo and the little plastic surround, get your hand in behind it once it's pulled forward, unplug the 4 or 5 connectors, wiggle speedo out behind steering wheel (removing s/wheel makes life so much easier but it can be done by prizing the top of the wheel back slightly for clearance) and find the bulb behind there. simple job, 5 mins max in reality
i've had my speedo in and out loads and loads, it's really simple Yes
i do believe your other airbags won't work tohugh if one has a problem No so don't expect your steering wheel airbag to go off.. i was told it was a circuit in which if one fails, they all fail. i didn't care cos i took them all out anyway
Posted 10th Dec 2009 at 20:15
braymond
air bag......sshhmair bag LOL
Thanks for the info - i'll get stuck in at the weekend.
Rallye-R
Nurburgring article
Posted 10th Dec 2009 at 20:25
sentrix
I've had the same problem since I brought my 6 and it's passed 2 mot's since with the air bag lighton.
Does it flash when u start the car then stay on solid afta 10mins of driving?
Freeman
Posted 10th Dec 2009 at 20:53
they should fail it if it's flashing really i think Unsure
if it doesn't come on atall they tend not to notice it. it should do the check on ignition. at that point if they know you have airbags and the light doesn't flash, it's obvious it's bodged or the light is removed. this is less obvious than a flashing bulb though
Posted 10th Dec 2009 at 20:55
mxcrazy
i asked my MOT test guys before i put my car in if the airbag light was a failure, and they said no, it went through fine too, about a month ago, i have buckets in mine also, so i wouldnt worry too much. Im too short (seats low) to see the light flashing over my steering wheel so dont even notice it anymore.
Posted 10th Dec 2009 at 21:40
barry.rs
My brother is an ex MOT tester and he also told me that the airbag light being on is not a failure.
Its a secondary safety device to a seat belt which must operate correctly.
Posted 10th Dec 2009 at 21:45
jonnyboy17
airbag light is not a failure.. ABS light is.. so you should be fine. if you want to be safe... as Rikky says... a few torx screws and the clocks are out.
Team Dirty Black... Formerly Known as Astor
sharland wrote:
When women don't behave like they do on brazzers.com in real life it disappoints me.
rikky wrote:
the day i own a credit card is the day i saw my helmet off and fire it from a potato cannon
Posted 10th Dec 2009 at 23:04
Removed mine when i changed the steering wheel for a momo as thi flashing light was doing my head in!! and correct i'm a tester and it is not a faliure.
Posted 26th Dec 2009 at 06:11
SteviePut
Or you could put a resistor across the plug. 17Kohms rings a bellSmile
Posted 26th Dec 2009 at 11:50
gazzerdaman
If the airbag is still fitted thats a pretty stupid idea, I most likely result in you getting smashed in the face when the airbag deploys LOL
Gary
Cherry Red GTi 6
Posted 26th Dec 2009 at 16:36
stebro-gti-6
air bag light is not part of an MOT can only advise
China Blue on Black Clones
Posted 26th Dec 2009 at 16:42
jaydog81
Just an advisory.
*jay81.
Phase 2.5/S-99
Team i live for working,Paying bills and funding my hobbies. I wish my life could be just living for a pink "I love the 6 sticker".Laugh my ass off
Posted 26th Dec 2009 at 19:14
mrdeey
Just to resurrect this post , from april 2012 AIRBAG LIGHT ON , will be an MOT FAIL
i was told this today when mot- ing my wifes cab !
now new booted , boosted and flying again!
Posted 15th Feb 2012 at 21:15
correct bit of the airbag light isn't there then they won't notice it LOL
Posted 15th Feb 2012 at 21:42
glenn_addo
If the airbag light flashes is it a fail or advisory? Any idea when in April as mine flashes and mot is due May
Posted 15th Feb 2012 at 21:52
mrdeey
Flashing is a fail from april , as most 306s gti6,s or not , flash the friggin airbag light , there are going to be a lot of fails!
Posted 15th Feb 2012 at 22:05
or rather a lot of people removing digit and actually fixing stuff properly, which doesnt take long at all...
Posted 15th Feb 2012 at 22:11
russbez
Whistle
i have no airbag installed though
My Rallye project thread
Posted 16th Feb 2012 at 16:08
simonjames
Been told that if the car was fitted with an air bag from April 1st it will need an air bag and working system to pass MOT ???
MY EBAY ITEMS
07943066306
Posted 16th Feb 2012 at 16:17
russbez
what about people with after market steering wheels Shut up
Posted 16th Feb 2012 at 16:44
mrdeey
If the airbag system was standard on the car it all has to work including the steering wheel , bit like the cat , has to be there for the mot
Posted 16th Feb 2012 at 17:04
rallyeash
shoulda bought a 205....
309 3dr K20 Type R
Posted 16th Feb 2012 at 17:06
