Author Subject: Thermostat Location
lingl9z
Hey all, can anyone tell me where the thermostat is located and how simple it is to replace? also would a low running temp also mean the oil temps low? as oil temps around/below 70 and takes ages to warm it up?
Posted 9th Dec 2009 at 14:27
If the thermostats stuck open it will make the oil cooler/take longer to warm up.
The thermostat is in the plastic housing on the end of the head on the right hand side of head as you look at it from front of car.
Find your top radiator hose,follow that back to engine and your thermostats in thereWink
Hardest part of job could turn out to be bleeding the coolant systemHuh?
Posted 9th Dec 2009 at 15:08
fletch
Track Head
If the thermostat has failed open, the car will take longer to warm up but should reach operating temp eventually.
Thermostat is easily replaced, its in the housing to the side of the cylinder head on the nearside. THere are 3 colored sensors, brown, green, blue that are screwed into the housing.
Posted 9th Dec 2009 at 15:13
fletch
Track Head
Doh too slow
lingl9z
cheers guys, the blowers blow hot air pretty quickly but the temp only reaches about 70-75 and goes up a bit in traffic, the oil temp is a also low.
Cheers Guys, i'll have a look at doing it at the weekend =D
Posted 9th Dec 2009 at 15:23
chrisd306
whats the brown sensor, water temp, as mine was plugged, now got 1 fitted
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 9th Dec 2009 at 15:32
cwspellowe
Aye think it's water temp, mine had come loose and the water temp light came on and both fans kicked in Thumbs up
Bye bye Sundance Kid Sad
Posted 9th Dec 2009 at 16:18
fletch
Track Head
The'yre all water temp Laugh
One for the fans, one for the ECU, one for the gauge.
If you unplug the brown (fan) sensor, the fans should spin up as a failsafe.
Posted 9th Dec 2009 at 16:19
cwspellowe
Well in which case we were right then Flip
Posted 9th Dec 2009 at 16:36
gazzerdaman
It was plugged up because you have a Rallye and they don't use the brown temperature sensor LOL
IIRC the FAN switch is in the right hand side of the radiator on a Rallye
The Brown sensor is for aircon cars that use the Bitron controlled dual fan setup.
Gary
Cherry Red GTi 6
Posted 9th Dec 2009 at 17:08
lingl9z
quick Q, the stat from euro parts, they any good ?
Posted 9th Dec 2009 at 17:15
best to use an o.e one tbh, its a 2 stage one IIRC.
Posted 9th Dec 2009 at 17:19
lingl9z
Do i have to get that from pug? as i don't have time to get down there? or can i order online?
Rich.
Posted 9th Dec 2009 at 17:22
Does that apply when fitting the Gti6 eng in a 309/205 aswell??????Wink
Posted 9th Dec 2009 at 18:48
lingl9z
Hey, got a thermostat delivered today but it didn't come with a rubber O ring seal ? where can i get one of these from other than pug as I'm sure it's that that's likely to have a split in any ways!
On another not I haven't seen a pug stat yet as haven't taken mine out yet but are they meant to kind of look lopsided? if that makes sence, like not centred.
Posted 11th Dec 2009 at 00:06
