Author Subject: Hi power engine rebuilld - Whats Safe???
pug_nick
Am currently sourcing a new 6 bottom end to stripp and rebuild. I am eventually aiming for a low boost charger setup. Just wanted a bit of advice on what the standard parts will cope with power wise. I will be spending a good 8month to a year building the engine so i dont mine splashing out to uprate.
Bottom End
Immeidate questions are about bottom end. Am planning the replace all bearings, bottom pulley, and flywheel, headgasket with richw parts as well as renewing all piston rings. I would like to know will the standard crank put up with 260-280bhp (thats what im aiming for) and will i need Forged pistons and rods for low boost. Also as ill have it all in bits is it worth having the block decked, and if i did would i need a custom headgasket to keep the valve/piston clearance correct.
Head
Was going to purchase a head after christmas to refurbish. Just a few questions about this. What cam shafts are the others with low boost running??? and also i have my eye on a brand new set of hydraulic lifters at the moment just wondered if it was worth buying them as i know some cams require a solid lifter convertion. And finnally are there any other parts in the head that will require uprating. I was planing on replacing all the valves and valve guides with standard parts.
Any help, suggestion and even photos of your rebuilds,setups would be helpful and much apprieciated. many thabks nick
Wanted list.
Coilovers
Cams (not too lairy)
Strut Brace
PM if you have any of these Cheers
Posted 8th Dec 2009 at 19:42
rallyeash
theres loads of people running 250+ low boost setups on standard engines mate. do a search and you shall find everything your looking for Smile
loads of threads in the project section too
309 3dr K20 Type R
Posted 8th Dec 2009 at 19:46
You shouldn't need to change the lifters at all, solid are only really for high rpm engines 8k+.
As above really, most people are running the low boost on standard engines with few problems. I would suggest speaking to Rich_W at Lynx directly about what you are after.
Posted 8th Dec 2009 at 20:02
pug_nick
ok thanks guys will drop him a pm and ill have a bit of a search
Wanted list.
Coilovers
Strut Brace
Posted 8th Dec 2009 at 20:12
rich_w
Nick,
Here are the answers to the questions in you PM.
Bottom End
- I would replace the main and big-end bearings with a heavy duty tri-metal type
- It's worth fitting one of our uprated head gaksets given the cost differential with the OEM item
- You can replace all other parts like gaskets / seals etc with OEM parts.
- The standard rods / pistons will be fine - but my advice would be to change them if there's any chance of you going high-boost in the future, whilst it's apart.
- It's worth decking the block to clean up the gasket face, you don't need to worry about the piston / valve clearance - it should only need 0.002 - 0.003" skimmed off to clean it up.
Head
- Use standard cams
- It's not worth changing the hydraulic lifters, or converting to solid ones. They don't break or wear out, don't change them.
- It's probably worth replacing the valve guides or getting them K-Lined
- Valves should be OK to re-use unless they are bent
- It's worth getting the valves ground and the seats re-cut for perfect sealing, don't lap them in the old fashioned way, get somewhere decent to re-cut them with a SERDI machine.
- Skim to clean up
As for discounts, yes, the more you buy at once, the better price you will get.
A complete low-boost S/C kit in DIY form is approx.
Contact Details:
07732 822546
Posted 8th Dec 2009 at 21:20
chrisd306
ive got 2 bottom ends mate if your after 1, got a bare 1 and a complete 1.
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 9th Dec 2009 at 02:36
pug_nick
thanks for the reply rich. thats a big help and will get me started. will contact you in the new year about a few of the bootom end parts and get them ordered. As far as the head is concerned do you have access to SERDI machine at lynx?? how much will this process cost?? thanks for the help.
Chris - am after a bottom end yes. would be looking for a comlpete one. PM a price pics etc. Will not be till new year now though. Thanks for the reply
Wanted list.
Coilovers
Strut Brace
Posted 9th Dec 2009 at 04:47
