displaying posts 1 to 2 of 2
Author Subject: Brake vac system
birk
Could someone explain how exactly the brake vac system works with the servo, the vac pump, the T-piece and the pipes attached.
Think the problem lies within this setup and just trying to figure it out.
Dan
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 5th Dec 2009 at 06:02
SteviePut
In short the vacuum created by the the vac pump acts on a diaphragm inside the servo which in turns multiples the braking force.
I don't know what your problem is but if you've got a vacuum leak or not enough vacuum at the servo I suspect that in the first instance you'd loose some of your braking effort. I'm not sure if this is connected in anyway to the inlet and could cause running issues.
I found this on Google which goes in to detail about how a brake servo works. It maybe of some useSmile
Posted 6th Dec 2009 at 12:59
