Author Subject: Rear Wiper Arm Removal
phil19gti
Quick question, does the rear wiper have a nut holding it on like the front ones, or does the boot interior trim have to be removed?
It needs tarting up a bit and would be better painted inside the house at this time of year.
Thanks.
2006 Performance Blue Mondeo ST TDCI
1999 Black 306 Rallye
1991 Lazer Green 205 1.9 GTi
2003 Blue Focus RS
1999 White 306 Rallye
1992 Red 205 1.9 GTi
1988 Red 205 1.6 GTi
Posted 4th Dec 2009 at 20:05
bennn
the actual arm part is held on by a nut no need to remove the motor.
Its only if you wanna remove the motor that you have to take out the boot trim.
Cherry Red 306 HDI
Posted 4th Dec 2009 at 20:11
bonzo
The arm is a right pain in the arse to actually get off in my experience.
When the nut is put on it pushes 2 parts of (what I presume is metal) together that kind of end up welding themselves together and are therefore a bit of a bugger to separate.
Ninja Black Rallye Ninja
Posted 4th Dec 2009 at 20:17
phil19gti
Does the plastic cover with the washer jets just lift up like the front ones?
2003 Blue Focus RS
Posted 4th Dec 2009 at 20:19
bennn
yeah it does. youll need some WD-40, a hammer and a lot of patience to get it off!
Cherry Red 306 HDI
Posted 4th Dec 2009 at 20:26
phil19gti
Nice one, I think I'll start the WD40 off tonight.
2003 Blue Focus RS
Posted 4th Dec 2009 at 20:27
tvrfan007
The fitting itself is a splined taper than sits inside a bush. The two corrode together.
Tape up your back window and stealth spray it on the car lol, it's far less hassle.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 4th Dec 2009 at 21:55
bonzo
Yeah, thats what I was trying to explain, just less successfully! LOL
+1 Thumbs up
Posted 5th Dec 2009 at 03:24
cress87
It's not that bad you pussies. LOL
Take the plastic cap off, then the nut and wiggle the arm towards and away from the screen and spray some penetrating fluid around the joint. Thumbs up
Don't go mental though else you could break the motor assembly.
Posted 5th Dec 2009 at 03:41
jonnyboy17
lift the flap.. remove the nut.. and pull... should slide off... mine came off no problem Thumbs up
Team Dirty Black... Formerly Known as Astor
sharland wrote:
When women don't behave like they do on brazzers.com in real life it disappoints me.
rikky wrote:
the day i own a credit card is the day i saw my helmet off and fire it from a potato cannon
Posted 5th Dec 2009 at 04:48
bonzo
I must have had half a can of wd40 on it, wiggled and pulled it to the point of being worried I would rip the boot lid off! LOL
Mine must have just been particularly 'weathered' I guess!
Posted 5th Dec 2009 at 05:53
tvrfan007
Dude I was plus gassing mine for a week, and my wiggling was more than persuasive lol.
If you have a bearing puller use it. I cut through the arm on mine as the motor was being binned anyway, and drifted the remains out of the arm in a vice. Whistle
I'm Si btw Tee hee
Posted 5th Dec 2009 at 15:02
phil19gti
Did this today, dead easy. Nut came straight off and then with a bit of persuasion so did the arm.
Now all painted up and ready to go back on.
2003 Blue Focus RS
Posted 6th Dec 2009 at 00:02
JG
Grr, in the process of trying to do this now.
Took the plastic cover off and the nut and the arm looks like it's joined to the thread. I take it that it isn't joined and should just slide off?
I've scrubbed it with a wire brush as it had discoloured etc so is it just a case of wd40 and wiggle then?
I only drink on two occasions... When I'm thirsty... And when I'm not...
W-reg Astor 306 Gti-6 Love
Proud member of the ASTOR Owners Club
Maybe for sale Cry
Posted 13th Mar 2011 at 20:13
cress87
It'll slide off now. The splines on the arm are just engaged with those on the shaft. Thumbs up
Edit: Is yours a phase 3? It might be different but I can't confirm one way or the other.
Posted 13th Mar 2011 at 21:33
tvrfan007
Phase 3 still uses a splined taper, you just can't see it as the bush inside the wiper arm will be stuck fast. Your only hope is to keep lacing it with penetrating fluid and pray. You'll more than likely break the arm getting it to come off. Use a bearing puller if you have one.
I'm Si btw Tee hee
Posted 13th Mar 2011 at 22:11
Rich E Forum Admin
I could tell just by looking at mine that it was going to be a right pain to do it on the car so I took the motor off the car, clamped it in a vice and cut through the aluminium centre that the arm had broken away from with a grinder.
Changing the arm took less than 15 minutes in total, including removing and replacing the trim panel and motor.
Posted 13th Mar 2011 at 22:23
JG
Yep ph3, I'm changing the motor so have a spare motor so can see how it connects.
Tempted to order a new arm and just bash the shit out of it Razz
If I loosen the motor and the sleeve I should be able to hit the pin with a hammer if you know what I mean... hmm
Maybe for sale Cry
Posted 13th Mar 2011 at 22:53
tvrfan007
If the motor is coming off cause it's faulty, cut the spindle off, then drift the remains out of the arm in a vice.
I'm Si btw Tee hee
Posted 13th Mar 2011 at 23:09
JG
Finally got it off, with light fading decided to cut the spindle as said. Razz
But when trying to remove said spindle from the arm the metal collar from the wiper arm came out, :/
New wiper arm time!
Anyone remember how much they are from Pug? Think I've seen them for £23 deliver on eBay.
Thanks
Maybe for sale Cry
Posted 14th Mar 2011 at 00:02
tvrfan007
Drift the spindle out now then, then glue/push it back in the plastic arm, it's only a press fit to start.
I'm Si btw Tee hee
Posted 14th Mar 2011 at 00:25
