displaying posts 26 to 36 of 36
Pages (2): 1 [2]
Author Subject: Miles' gear linkages
jimbamboon
just got these through, are the joints at each end supposed to be rotated in slightly different positions? It would make sense as theyre all like that
clicky code for my benefit
Posted 17th Jun 2011 at 23:58
Yes they are meant to be like that.
Posted 18th Jun 2011 at 00:00
honestly3k
How are the new linkages? Do you notice the noise? Did you lubricate yours?
Contemplating getting some
Posted 3rd Jul 2011 at 16:55
mattyrallye
Just any grease i would say. Something is better than nothing. I always used Mobil grease at work for this type of application and it always worked.
I would just like to add Miles is a top lad, he called me when he promised he would, and he sent them through Thurdays and they arrived today. Cant fault him. TOP MAN.
Previous china gti6 and Rallye owner.
Now a proud Astor Gti 6 owner.
Missing he BMW already...
Posted 8th Jul 2011 at 17:35
lewisdmz
Is the top short linkage supposed to be able to move around side to side rotating on the balls? I would have thought so but the other's don't seem to move?
Posted 8th Jul 2011 at 18:01
I think the other two won't as they're twisted and that one's straight. Pretty sure that's fine, mine was the same Yes
Tee hee, he said balls.
Posted 8th Jul 2011 at 18:04
jungle jim
I ditched the grease idea and used a tiny 1mmx6mm o-ring (for the small ones, and an 11mm one for the big one) on top of one end of the ball joints... this then site inside the cup when they are pressed on. Removed all vibration from the linkages, so no noise from them any more - and still the same excellent shifting.
200+ secret squirrels hiding under the bonnet with 4 wide mouth frogs...
Posted 14th Jul 2011 at 16:30
lewisdmz
Mine are pretty damn noisy at the moment, even cruising at 80 in 6th there's a slight rattle. Goes away if you just push the lever towards the passenger side a tiny bit.
Posted 24th Jul 2011 at 21:08
cwspellowe
I packed mine with moly grease a year ago and they're still spot on
Bye bye Sundance Kid Sad
Posted 29th Jul 2011 at 17:47
davedgti6
Post #35
Mine was noisy, what I did was remove the heatshield and removed the gearstick completely, then I exposed the "ball" cleaned it and greased it up, put it all back together and noise has gone since, I did notice however that the ball had several cracks in it and could have done with replacing really.
Posted 29th Jul 2011 at 20:33
lewisdmz
Post #36
Thanks Dave i'll give that a go, I noticed yesterday the long rod from gear stick to linkages has a lot of play in it so something in that area needs looking at.
I saw in another thread Miles' linkages come with circlips which I guess go around the ball? Mine don't have these (came with the car) which could be the cause of the up-down movement.
Posted 7th Aug 2011 at 16:41
Pages (2): 1 [2]
