Author Subject: handbrake light staying on?
skinnyman76
hi guys as above brake light stayin on in dashboard and pedal seems to have more play andbe going further down than before? any ideas? cheers
pug power !!!
i got the need for a 6 speed!!!
Posted 3rd Dec 2009 at 21:23
cress87
I know this has been discussed previously but I can't remember the details. One of the brake warning lights indicates low brake fluid level, I can't remember if it's the handbrake light though. Worth checking anyway. Smile
Posted 3rd Dec 2009 at 21:28
skinnyman76
cheers man will do
pug power !!!
Posted 3rd Dec 2009 at 21:30
i completely forget but isn't the handbrake warning one a totally seperate light to the brake fluid / pad warning light?
if it's the handbrake light i'd have thought it would be the 2-pin blue plug/sensor in the middle of the exhaust tunnel (i have never ever ever known one fail though)
sounds like you have a pad/bleeding/fluid issue though. check fluid, then pad life, then pad sensors
Posted 3rd Dec 2009 at 21:38
skinnyman76
cheers rikky pads r all good i will try fluid 1st then maybe bleeding if needed thanks
pug power !!!
Posted 3rd Dec 2009 at 21:44
smighall
Smeg-all
Brake fluid comes up as the handbrake light Yes
Meh
Posted 3rd Dec 2009 at 21:48
skinnyman76
sounds like my fluids low then that would explain my pedal 2 i suppose! i will look into it in the mornin once ive got some light again.
thanks every1
pug power !!!
Posted 3rd Dec 2009 at 22:18
honestly3k
Handbrake means low brake fluid, probably have a leak in one of your brake lines....as i did....simple fix...and relitevely cheap...its just finding the bugger!
Posted 4th Dec 2009 at 00:04
skinnyman76
hi guys got a look today master cylinder is leaking down the bulk head.. looks as if it could be a sealing issue though ive been told master cylinder is more likely gubbed!! any1 have a lying around ?? cheers
pug power !!!
Posted 4th Dec 2009 at 19:42
