Author Subject: bottom crank pulley removel
duanedibbs
can anyone help please im trying to take of my crank pulley due to it falling to bits but i cant undo the friggin nut that holds it ive tryed a air gun and still no joy any ideas please.plus does it undo anti clockwise? many thanks
Posted 2nd Dec 2009 at 20:56
dan_xsi
have you got the flywheel locked with something, beacause if not you will never get it off, the engine will just turn over backwards which isnt advisable. And yes it undoes backwards
Posted 2nd Dec 2009 at 21:14
duanedibbs
is the flywheel the bit its conected to with the rubber inbetween coz if it is thats the bit thats fell of soz for sounding thick i just aint got a clue
Posted 2nd Dec 2009 at 21:20
paulchin
The flywheel is the large lump of metal at the other end of the engine, between the engine and the gearbox - what keeps your engine turning over.
I got my pulley off by a mate standing on the brake whilst in gear - worked for me. Just use a long enough handle on the socket bar to get the leverage - should go with a bit of a crack, but it does go.
(I've heard horror stories about fixing a long-handled socket to the bolt, jamming it into the floor then spinning the engine on the starter - not recommended!)
Posted 2nd Dec 2009 at 21:55
duanedibbs
yeh mate someone told me to try that one but didnt fancy doing that
Posted 2nd Dec 2009 at 22:02
fletch
Track Head
Lock the flywheel and get a big bar/scaffold on it.
Posted 2nd Dec 2009 at 22:10
duanedibbs
thanks for you replys how do you lock the flywheel of
Posted 2nd Dec 2009 at 22:16
lotek
foot on brake and in gear , when stan took mine off. Yes
Posted 2nd Dec 2009 at 22:17
pugjim
Theres an 8mm hole in the block at the flywheel end behind the start motor what u put a rod through and it locates in a notch on the flywheel to lock the engine.
Posted 2nd Dec 2009 at 22:36
duanedibbs
thanks for all your help will try them tomorrow cheers
Posted 2nd Dec 2009 at 22:55
Righty tighty, lefty loosey LOL
Posted 6th Dec 2009 at 00:43
higgy306
Valid question, as some crank pulley bolts on different cars are reverse thread Crazy
Posted 6th Dec 2009 at 03:28
gtylerroberts@manx.net
So - In case I have this the wrong way around - the crank pulley bolt undoes by turning anti clockwise as a standard bolt. Is that right?
Posted 7th Nov 2010 at 22:27
mabgti
NV motors
yes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 7th Nov 2010 at 22:40
