Team- Blaze.
| Author | Subject: sachs kits???? |
gti-6kerr
Regular Location: barrow in furness Registered: 15 Feb 2008 Posts: 123 Status: Offline |
Afternoon all, i have been looking at some sachs clutch kits on the net and i have found 1 for ________________________________________ Team- Blaze. |
you can usually get Valeo for less, but never had a problem with Sachs, though not fitted one to a gti6.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jose
Senior User Location: W.London Registered: 05 Oct 2008 Posts: 675 Status: Offline |
got the one from euro car parts fitted in my car, no problems to report at all, and have been told they are really good kits ________________________________________ Nile Blue GTi6Alpine White 205 GTi 1.9 - Project Air Con Pipes Thread....... Machine Polishing - Paint Correction - Swirl Removal in West London - PM for details |
jib
Seasoned Pro Location: Doncaster Registered: 21 Feb 2008 Posts: 1,842 Status: Offline |
Becareful with this.I got a sachs clutch last month from euro car parts....or so i thought! It turned out to be a Valeo one in a sachs box! |
gti-6kerr
o.k cheers, so how did you tell the difference when it came?? are they stamped?________________________________________ Team- Blaze. |
Rich E
You will most likely get a Valeo unit when you buy a Sachs kit for the GTi-6 ![]() I also purchased one from ECP and found a Valeo kit inside. I raised this with their technical support team who checked the Valeo part numbers against the Sachs kit number and confirmed the parts were correct. Sachs don't make a kit specific to this application themselves so they will always buy part (if not all) of the kit in. I was told that Valeo is their preferred supplier for this application but they do sometimes use other brands too, and I believe some people have had LUK parts included with this kit. That said, the Valeo kit I received was not the same one as Valeo sell themselves for the GTi-6. Both parts were different; the friction plate had one pair of springs much larger than the other pair quite like the factory fitted clutch and the cover looked more sturdy and had a better release bearing with it. Having used both the OEM Valeo kit and the Valeo one supplied by Sachs I would pay the extra for the Sachs supplied one as it is definitely a better kit. ________________________________________ Rich |
gti-6kerr
o.k thanks all for the info________________________________________ Team- Blaze. |
jib
Rich E wrote: You will most likely get a Valeo unit when you buy a Sachs kit for the GTi-6 ![]() I also purchased one from ECP and found a Valeo kit inside. I raised this with their technical support team who checked the Valeo part numbers against the Sachs kit number and confirmed the parts were correct. Sachs don't make a kit specific to this application themselves so they will always buy part (if not all) of the kit in. I was told that Valeo is their preferred supplier for this application but they do sometimes use other brands too, and I believe some people have had LUK parts included with this kit. That said, the Valeo kit I received was not the same one as Valeo sell themselves for the GTi-6. Both parts were different; the friction plate had one pair of springs much larger than the other pair quite like the factory fitted clutch and the cover looked more sturdy and had a better release bearing with it. Having used both the OEM Valeo kit and the Valeo one supplied by Sachs I would pay the extra for the Sachs supplied one as it is definitely a better kit. Cheers for the Rich. I did wonder if there was a difference between the OEM and sach's kits. |
gtisid
Seasoned Pro Location: chelmsford Registered: 22 Mar 2003 Posts: 4,992 Status: Offline |
this is weird , although a few years back the first clutch i fitted to the 6 was a sach clutch. It looked different to the valeo one as the clutch was not held together with rivets as the valeo one is. I specifically asked for a different clutch as the one fitted previously as it was the rivets coming loose that caused my valeo one to fail.Maybe they have changed their pattern , i dont know but the sach one i had was not the same as the valeo one ________________________________________ puglessPhase 1 GTI 6 1996-1997 Subaru Impreza GB270 2007-2008 rare spiderman comics same day international courier |
