Author Subject: Radiator Fix
chewitt
Hi,
My radiator has a leak and the AA has told me to replace it.
I am replacing it tonight but need to get my car to the garage. I was told by a friend I can use some sort of putty to stop the radiator leaking while I drive it there.
It doesn't take long while driving for the engine to overheat due to loss of coolant.
I am going to use Magic Bond Epoxy Stick.
Will this hold the leak for a 20-30 minute town drive (traffic etc)?
Thanks.
306 LX 1.4 Phase 2
**Current Body Mods**
4 x 4" Exhaust System
Full B/Kit (Front, Skirts, Mirrors & Rear)
Bonnet with Scoop
Full Tinted Rear Windows
17" Alloys
Lights
Posted 1st Dec 2009 at 20:23
where is it leaking?
Posted 1st Dec 2009 at 23:26
toby
Probably safer to toe it than risk damaging the engine, remember if there is no coolant in the system you won't get a correct reading from the temp sensors, fand won't possibly come on either.
Previous Peugeot - 2000(w)GTI-6, Me old China, Supercharged with working aircon!
Posted 2nd Dec 2009 at 00:02
smegal
Radweld and carry LOTS of water. Would the AA not take it home?
Ex SC-6
Now in a Megane R26
Posted 2nd Dec 2009 at 00:18
jimmyrallye
^^^ as above that should get you home
Posted 2nd Dec 2009 at 01:18
never use radweld, unless you want to remove your dash to do a heater matrix Thumbs up
Posted 2nd Dec 2009 at 01:58
chewitt
Well I used the epoxy putty on the hole.
The hole was at the top of the radiator.
It wasn't visible but you could see water spraying out near the top of the radiator whenever you squeezed the top pipe.
I formed the putty around the hole and let it set for an hour, my car drove to the garage like it didn't even have a problem!
Temp guage moved up a little but never went over about 70
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 2nd Dec 2009 at 13:52
toby
Rad weld is a real no no, just think about what it does and where else it might end up!
Posted 2nd Dec 2009 at 18:41
Indeed - you should see what it does in quantity to wet-lined engines. I have used very small amounts to keep the matrix going for a couple of extra years, but always better to fix the leak.
Speaking of which i've got a couple to do myself Sad
Posted 2nd Dec 2009 at 18:56
