In order to start on a normal morning, i have to give it a boost with the throttle before it fires into life, and after that for the next minute it dips and dives around 1000revs.
My next problem is this, the Engine Taps loudly - A lot less after i did an engine flush and oil change.
Obviously it increases the more i rev, This is confusing me and damn well annoying to say the least.
Since the oil change i have put some oil treatment in which is supposed to quiet the engine down a bit to no avail.
Any help that could sort this problem out will be greatly recieved, as i say nothing like this happened before the head gasket change.
Richies Project RallyeElectrical work carried out in Portsmouth
rich306
You may find that your crank pulley has slipped and when they pinned it all up to refit the timing belt the could have got the cams position a little wrong relative to the crank, this could easily bend a valve and cause starting/running issues.
