Author Subject: rear wiper arm removal
gota6again
Trying to remove the rear wiper arm but it won't budge, is it just supposed to slide off or do I need to do anything else? Looked through Haynes manual and that says slides off?
EDIT: Phase 3 if it maks any difference
EDIT AGAIN: Removing due to trying to fix it, not to remove it for looks Whistle
Posted 28th Nov 2009 at 20:01
ballys16
If you removed the nut it should come off - although rust tends to make that bit quite hard to accomplish.
XSi 8V -> S16
Posted 28th Nov 2009 at 21:08
tvrfan007
Bearing puller is usually required as it's a tapered spline, and corrodes into place.
Seeing as mine was dead i cut through the spindle, drifted the taper out in a vice and refitted with copper grease on the new motor.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 30th Nov 2009 at 18:11
