Author Subject: Detailing the bay
jambo85
Know this has prob been asked a few times but i cant find any proper threads going into detail.
Im looking to clean the engine bay on my new 6 and want some do's and dont's. I dont have a pressure washer and not my favoured option as im terrified i drown the engine. Whats the best technique in getting the engine sparkling and what sort of things should i cover? Should i remove anything before starting to make it easier?
Any pointers would be helpful.
Back to my phase 2 in black on the road.
Phase 3 sold after spending fortune on it.. It wont be missed.
AFTER a phase 3 tailgate in black and front bumper in ace condition.
Posted 27th Nov 2009 at 23:40
Hot water pressure washer was fine when mine was done nothing covered up at all. However it did take the text off the aircon regas sticker (no loss apart that i've now got a blank sticker) and some of the paint off my power steering cap.
Peace of mind should included fuse box and some of the exposed electric but tbh it's probably ott.
Posted 27th Nov 2009 at 23:44
allesclar
what i do, is to use engine degreaser all around but apart from on paint. Also a good note is to wet the side wings just incase water drips down the side with engine decreaser.
i leave it for about 15mins, then with the jetwasher i go over the entire engine but DONT hold it over an area for more than a few seconds. I also keep the engine running too, this avoids the engine not being able start up again. Although i will probably get slated for doing that Razz
Thats what i do anyway Smile
Team allesclar ®
jambo85
Nevermind me trying using the word clean instead of detail and found loads of threads
Posted 27th Nov 2009 at 23:50
jambo85
Cheers guys appreciate the tips
Heard daisy cleaner from tesco's is pretty good for this?
Posted 27th Nov 2009 at 23:57
spitfire
Jamie I can't really say that I agree with all of the above (just my opinion).
Cleaning the engine is a relitively simple task and definetly gives very rewarding results.
There are two ways I would go about it.
1)With a quality steam cleaner that produces a constant flow of steam under presure of 120 degrees or higher, this method means no need for chemicals.
2)Warm the engine until warm (not hot), cover up any thing that you shouldn't get water into and then spray enginge cleaner over everything, agitate into all the dirty areas and rinse off with an open hose, repeat if necessary. Then go for a drive to dry everything off.
Then which ever method you have done you will need to re-grease any parts that should have grease on, and then the engine bay needs protecting, just like you would protect the body work. I use Sonus Trim and Motor Kote for this, spray on a light coat and let dry then a second coat (do this when engine is cool and dry).
I wouldn't have the engine running as if water gets into the air intake you could suck it into the engine ..... and disaster.
I wouldn't use a pressure washer as the water is under such high pressure it can be forced passed seals say on a plug and casue problems.
Here is a picture of my bay after it was done in the summer.
If you aint first, your last!
Posted 28th Nov 2009 at 15:49
jambo85
Cheers for that mate sounds i good way. My only question is what things should i be covering? Im assuming battery, wires etc but what else could cause damage when wet?
Posted 28th Nov 2009 at 16:39
spitfire
Jamie, doing a '6' engine as long as you don't have an aftermarket induction kit, there is nothing that you really have to cover up, all of the plugs have waterproof covers on them fuses boxes have covers so should be fine as long as you don't go blasting high pressure water at them. You could just stick a plastic bag over the battery if you want but not essential.
Posted 28th Nov 2009 at 16:57
jambo85
Cheers. No put it back to a standard filter so no worries of it soaking up the water. Hopefully when i finish work its dry and i'll give it a bash... Pity i stay in scotland and its permantly raining!
Posted 28th Nov 2009 at 17:08
i find taking the engine out and pushing your car outside your house to jetwash it properly gives rewarding results LOL
Posted 29th Nov 2009 at 16:01
Main thing to cover is the alternator, as all the open vents in the top will allow water to pour in.
Posted 29th Nov 2009 at 16:05
