Author Subject: brake switches
Ben_gti-6
Are brake switches easy to fit? an how much do they normaly cost, i suspect this is the reason i have no brake lights, i have already checked the fuses an all the other lights workHuh?
More than happy with my re-mapped T5
Posted 26th Nov 2009 at 23:28
jimmy_boy
If you are double jointed then yes! LOL
Get down in the footwell and look up at the steering column.
Not sure on cost though as I've never heard of one failing.
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 26th Nov 2009 at 23:38
Ben_gti-6
i cant think what else it could be an i have the dreaded m.o.t next week Unsure
Posted 26th Nov 2009 at 23:41
t11hac
Yep they are easy drop the steering wheel 4 13mm bolts I think then its just a case of feel for the hole you should me ok just remembered the steering column is very sharp so be careful Big grin
Team Black Rallye
Posted 26th Nov 2009 at 23:43
t11hac
You can join the cable to check this with out removing the switch mate Razz
Team Black Rallye
Posted 26th Nov 2009 at 23:45
jimmy_boy
I've had one pop out of it's position but usually this results in the brake lights being "ON" all the time.
It's a push to turn off setup.
GTI-6 & Rallye
Ben_gti-6
how do you do this? an which way does the switch come out, back through the steering column?
thanks
Posted 27th Nov 2009 at 00:08
t11hac
Yea it dos you have to remove the heater pipe its just a small bit to the left of the steering column then drop the column to get in to it you will see a hole in the metal its in there
Sorry I cant be muck more help
Team Black Rallye
Posted 27th Nov 2009 at 00:12
oecken
it must be that time of year or something, ive read of 3 other people with the same problem today, and me ! (Now fixed mind)
Posted 27th Nov 2009 at 02:21
gota6again
Mine did this a while back but fixed itself after me stamping on the brake peddle?!
Posted 27th Nov 2009 at 02:31
Ben_gti-6
LOL worth a try i suppose!
Posted 27th Nov 2009 at 02:51
Ben_gti-6
how'd you fix it?
oecken
Ben_gti-6 wrote:
how'd you fix it?
luckily it was in the garage for a service and new ball joints. so got them to do it. i think they had an employee with hands of a child LOL
Posted 27th Nov 2009 at 03:03
Ben_gti-6
oecken wrote:
Ben_gti-6 wrote:
how'd you fix it?
when i worked in a garage one of my collegues could fully tighten an exhaust clamp around his wrist an still get his hand out, where as i have piano fingers an huge palms so i think i am going to struggle Unsure Blink
Posted 27th Nov 2009 at 03:39
smegal
DO NOT DO THIS !!!!!!!!!!!!!!!!!!
Ex SC-6
Now in a Megane R26
Posted 27th Nov 2009 at 05:03
smegal
Take the vent out. Open the fuse box, drill the rivet out for the heater pipe, then pull the heater pipe out and put your hand down the hole to reposition the switch.
If you look from below you can see where the switch is.
Ex SC-6
Now in a Megane R26
Posted 27th Nov 2009 at 05:05
Ben_gti-6
I have fixed the problem with some cardboard an stickytape (no joke) an yes it was the switch Smile
Posted 29th Nov 2009 at 18:52
gilesy
My switch failed, got a new one and ended up taking the drivers seat out just so I could see what I was doing! Pop the drivers side vent out and reach in through there.
Me and my mate looked like we'd been self harming, we were cut to shreds!!
I knew a guy that worked on harriers which apparently are pigs, he kept getting called in off-watch as he had really skinny hands
Posted 29th Nov 2009 at 18:56
jimmy_boy
Haha! What a p*ss take they are!
GTI-6 & Rallye
Posted 29th Nov 2009 at 19:06
smegal
I did this. The only problem is this can then push the switch further back. I had to change my switch a few days later.
Ex SC-6
Now in a Megane R26
Posted 29th Nov 2009 at 19:19
Ben_gti-6
very true i was thinking this, will see what happens Huh?
Posted 29th Nov 2009 at 19:37
billywhizzer1
nightmare mine went on my old phase 3 i decided in the end to let performance 3000 do the honors,im glad i did it didnt cost that much and saved a broken neck LOL
Posted 1st Dec 2009 at 00:12
billywhizzer1
dont go there, done research the job is a nightmare, and the garage dont charge much on this oneSmile
Posted 8th Dec 2009 at 00:55
