Author Subject: 205 Gti 1.6 Compatibility
Not exactly the right forum I know but I'm sure someone will have the info I need on here. Will Gti6 calipers bolt straight on and work with the standard disks and hoses? Or will I need other parts to make these fit?
Thanks in advance Smile
Posted 26th Nov 2009 at 15:53
lotek
im pretty sure the calipers are ok, not sure about the discs tho.
my friend paul put 307 hdi calipers on his
205-gti6, and the 307's fit the 306, so it should be ok.
Posted 26th Nov 2009 at 15:59
anderoo
I think you might need to fit the hubs from a 1.9 GTi. Unsure
Pics of my 6
My 6 on Google Video thanks to coxy306Xsi
Posted 26th Nov 2009 at 16:15
gti6girl
1.9 hubs are needed yes Smile
Posted 26th Nov 2009 at 16:48
What disks will it need then, ordinary 1.9 ones or Gti6 disks?
Posted 26th Nov 2009 at 17:24
pdd144c
1.9 hubs and driveshafts, gti6 calipers and discs.
FOR SALE
205 Turbo Technics complete and 306 Rallye Race Build breaking.
Posted 26th Nov 2009 at 17:30
Not a straightforward job then, poxy 1.6's Razz LOL
Posted 26th Nov 2009 at 17:41
pdd144c
Haha very true! What's the car being used for?
FOR SALE
Posted 26th Nov 2009 at 17:48
Not my car, it's a friend of a friend's, he said he needed to get his brakes up to scratch for a trackday (first one) and as I have a set of standard calipers going spare it seemed like the ideal solution, probably too much effort/expense I expect. A set of braided lines, decent fluid and some DS2500s should see him through though.
Posted 26th Nov 2009 at 17:56
timredrallye
That's the way forward. You can get away with cheap discs on these, but don't scrimp on the pads. Also more often then not, the callipers are past they're best so make sure they are greased up correctly and your mate should see a large difference.
Just serviced the brakes on my standard 1.6 and I was amazed with the improvement in braking effort.
On an otherwise standard car, standard brakes should be up to the job unless you are really serious.
Posted 26th Nov 2009 at 18:09
pdd144c
1.6 brakes do seem to work quite well with lines, fluid and pads. That's what I'd go for.
FOR SALE
Posted 26th Nov 2009 at 19:12
Looks like I need to find another buyer for my calipers then...
Thanks for the advice though chaps Smile
Posted 26th Nov 2009 at 19:21
Especially if it has had any lightening - they really just need the standard brakes in good nick and decent pads.
Posted 26th Nov 2009 at 19:26
mr swampy s16
**BAD SELLER**
Point him my way for set of lines.
Posted 27th Nov 2009 at 00:23
Will do, I think he may try to find a 1.9 setup, but will let you know Thumbs up
Posted 27th Nov 2009 at 00:24
mr swampy s16
**BAD SELLER**
Front lines are same on both
fairly sure he needs 1.9 hubs with 1.9 calipers.
If he does he may as well fit ur gti6 calipers
Posted 27th Nov 2009 at 00:30
I know, I don't think he has realised that just yet, however if he finds a complete 1.9 in a scrappy then all the bits he needs for a decent setup are there. Cool
Posted 27th Nov 2009 at 00:32
you dont need 1.9 hubs to just use 1.9 calipers, just stick to the 1.6 discs.
go to Miles for brake lines, they're cheaper and higher quality, and local Thumbs up
if its a stock 1.67 it'll be fine on the 1.6 brakes and decent pads, if its a 16v engine it'll be fine on 1.9 brakes, gti6 is overkill, and being a 1.6 they wont fit under the wheels unless they have been changed.
to get gti6 brakes to fit on there cheaply, fit base model hubs, you can keep your 1.6 driveshafts then.
Posted 27th Nov 2009 at 01:05
mr swampy s16
**BAD SELLER**
Again you are spouting crap welshpug
cheaper? Nope!
Better quality ? Nope!
I would say the company that supply my hoses and make them for several of the very large brake companies who rebrand them as there own probably make as many lines a week as miles does a year!
So i suggest you keep your wild accusations to your self until you have first hand experiance.
Posted 27th Nov 2009 at 01:37
lol
Posted 27th Nov 2009 at 01:48
miles
You don't need 1.9 hubs at all (As WP said), Just use Base model hub's with the 1.6 shafts, Easy as and then you can fit most Callipers from the PSA range, Avoid HDi or 307/206 Gti as the pads are silly money.
Also a bonus as you can run the right offset for larger wheels too.
Hose wise you cannot really use std 1.6 or 1.9 lines as on full droop and lock then can bend reducing flow slightly and is a MOT Failure
But I say my lines are the same price for Stainless as Swampy's Zinc plated one's and quality wise I doubt there's anything in it like for like if there is a stainless version.
But it's not something I market as there's no margin in them which at the end of the day and we almost all have overhead's, Rent, Rates to pay if in full time business.
All zinc plated stuff to me is Rubbish as it will corrode like all the other plated parts on car's
www.pugracing.com
Posted 27th Nov 2009 at 02:52
mr swampy s16
**BAD SELLER**
Same price?
Your ebay shop lists them at
Posted 27th Nov 2009 at 02:51
miles
Thats ebay dear boy, You can make a nice mark up there, I don;t use the old Rare word which allot do and make even more
Forum members get them allot cheaper, price I will not disclose unless PM'd
www.pugracing.com
Posted 27th Nov 2009 at 02:54
