Author Subject: INFO:2.1 conversion
simonjames
Well i've bought a 306 D-turbo to break today so looks like i have a crank now Smile
along side my pistons/rods and crank
Here are the 1s i have
what other parts/work am i going to need
what main and big end bearings do i need?
do all the 6 bits I.E pump chain pulleys all fit on the diesel crank or would i need to use diesel parts
MY EBAY ITEMS
07943066306
Posted 26th Nov 2009 at 01:10
mxcrazy
are the rods and pistons gti fitment? or s16, obviously by increasing stroke the pistons will sit 1mm higher than a stock 86mm stroke crank, i think the common way is to use s16 or mi16 2.0 rods and pistons, cos they sit 1mm lower than GTI pistons as stock.
Posted 26th Nov 2009 at 16:24
simonjames
they are the gti pistons and i do beleive that they will need machining on the top to get clearance
MY EBAY ITEMS
07943066306
Posted 26th Nov 2009 at 17:35
you'll need to machine more than just 1mm off the top edge if you want to retain the compression ratio at 8.0-1.
depends how much meat there is on them, you may not have enough there to keep it down.
everything should fit fine as far as I know regarding the crank.
2068cc is what you'll get on 86.5 bore x 88 stroke.
Posted 26th Nov 2009 at 19:11
simonjames
only way i'll really know is to trial fit it then really and see how far past the top the piston comes
MY EBAY ITEMS
07943066306
Posted 26th Nov 2009 at 19:15
not so much that, but how much the dish needs making bigger.
should have a compression height and dish size quoted for them, might be on the box.
add the compression height to half the stroke (44mm) and the length of the conrods (158mm) and subtract that from the deck height of the block. (234.5mm IIRC)
then you have the chamber size and gasket voulme to take into account, plus the decreased dish depth due to the skim.
I'd speak to Rich or Wossner and see if what you have is suitable, I know the compression height of the 6 piston isnt that great so trying to take a mm off them might be asking too much.
Posted 26th Nov 2009 at 19:24
simonjames
i did send rich a pm a few months back he said the tops would need machining
i've also got to take in to account that the black has also been decked (not sure by how much though)
i'll have to read the box it see the figures for the pistons maybe im better off just sticking with the std crank
MY EBAY ITEMS
07943066306
Posted 26th Nov 2009 at 19:30
Doh
time for a dry build of the bottom end then!
Posted 26th Nov 2009 at 19:31
simonjames
yeah i dont think im gonna know really till thats been done, also theres not that many competant machine shops round here that i would trust to machine a brand new set of wossners so i my need to coriour them out
MY EBAY ITEMS
07943066306
Posted 26th Nov 2009 at 19:32
