Author Subject: Camshaft in 1.8 16v
sergiorallye
Hello I want to know if the camshaft of gti6 can put directly to the engine on 1.8 16v?. Or is it necessary to modify something?
A greeting.
Sergio
Posted 24th Nov 2009 at 04:42
jcphat
They go in fine but you have to have the pulleys too.
New Forum same high quality intellectual debate!
Team Zimmer™
Posted 24th Nov 2009 at 04:59
sergiorallye
Do not the pulleys of the 1.8 16v cost him??
Posted 24th Nov 2009 at 05:00
cost??
the 1.8 pulleys have a different angle on the camshaft to the 2.0 engines.
Posted 24th Nov 2009 at 15:05
24seven
you need the 1.8 pulleys AND hubs. both can still be bought new from peugeot for a reasonable price. You need to check whether the pulleys are attached using 1 bolt or 3 bolts. If it's just the 1 bolt (I believe most are this type) then the part numbers you need (courtesy of welshpug a year or so ago) are:
0805 A3 CAMSHAF GEAR 42 DENTS - INJECTION XU10J4RS
0805 82 PINION HUB BE - BLUE- INJECTION XU10J4RS
you need 2 of each. When I did this the Hubs were around
Posted 24th Nov 2009 at 18:22
sergiorallye
Thank you for the information, only it is necessary to change this, does not touch valves? Have all the degrees these camshaft of series?.
Already I put him the collector of admission and that of leak.
A greeting
sergio
Posted 25th Nov 2009 at 20:12
asim_pug306
How much improvement does this actually give to the performance?
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 30th Nov 2009 at 01:40
as far as I know nobody has actually had a before and after Dyno run to gauge how much of a difference it makes, I think Sandy Brown might b able to give a vague figure of estimation as he has run one on throttle bodies in a 309 goodwood, as well as built a 211 bhp race version
Posted 30th Nov 2009 at 04:50
