Author Subject: Stiff throttle pedal
phil19gti
My throttle pedal is quite stiff. Reading up on past posts it seems like it's worth lubricating the butterfly.
Is this the best thing to try or could be it be something else? And if so, where is it?
2006 Performance Blue Mondeo ST TDCI
1999 Black 306 Rallye
1991 Lazer Green 205 1.9 GTi
2003 Blue Focus RS
1999 White 306 Rallye
1992 Red 205 1.9 GTi
1988 Red 205 1.6 GTi
Posted 23rd Nov 2009 at 19:04
The cable could be frayed.
Posted 23rd Nov 2009 at 19:23
phil19gti
Is it difficult to swap the cable?
2003 Blue Focus RS
Posted 23rd Nov 2009 at 19:25
If you buy a new one, you could get away with just swapping over the inner wire and lubricate it.
Posted 24th Nov 2009 at 00:32
dr-evil
Unhook the cable from the throttle body completly and feed 3n1 oil down the cable while working the inner in and out should free up a lightly clogged cable, if it doesn't free it up within a couple of minutes then hang it up on the underside of the bonnet to let it work its way down - you could also try throwing some on the pedal pivot but will be awkward.
As far as the butterfly goes if it has some baked on crude on the outer edge of the butterfly then it will drag through its movement - a scrub with carb cleaner will remove it Smile
Cad Monkey will work for chocolate biscuits....I'm not kidding
Posted 27th Nov 2009 at 17:46
