Author Subject: Radiator Problem
dyl4n
Hi, ive recently fitted a 2.0 16v xsi engine in my 8v xsi.
Im having a bit of a problem with the radiator.
What are the two small pipes at the bottom driver side of the rad go? Can i loop them together?
Also, in case it would make a difference, i've looped the heater matrix pipes together.
If In Doubt....Go Flat Out
Posted 21st Nov 2009 at 04:50
ballys16
Do you have access to Service box?
You can see for yourself how the hoses are meant to be connected.
XSi 8V -> S16
Posted 22nd Nov 2009 at 05:01
rich306
Just block them up mate, no need to have them on the XSi, Put a bolt in each one then cable tie them
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 22nd Nov 2009 at 05:32
