Author Subject: major missfire
carl.swan
My 6 has let me down once again but i'm getting used to it now. since u've had the car and through various engines and heads (2 completely different set of engine sensors) the car has always had a flat spot/hesitation that this afternoon developed into it not being able to pull itself along ticks over okay ish but sort of on 3 but as soon as you try to rev it it splutters and then dies. now i cant even get it to start it just fires as you spin it over.
i'm starting to think that maybe the fuel pump has gone faulty. has this happened to many others on here? i.ve never had one fail on me before with owning lots of peugeot/citroens but everything else has been changed including coil packs etc
any ideas, ECU maybe but i doubt that.....
thanks
8th 2008
14th 2007
29th 2006 (Novice Year)
Yokohama Demon Tweeks Stock Hatch Championship
swanracing on youtube for video's
Posted 20th Nov 2009 at 22:44
mad_dave23
Injectors?
Posted 21st Nov 2009 at 01:10
vts_gav
injector relay or crap pump
Posted 21st Nov 2009 at 02:26
allesclar
another vote for injectors, you checked the TB sensor?
Team allesclar ®
Posted 21st Nov 2009 at 02:31
mechanical_repairs
If you are able to get the car over to me i am sure i will have enough spare sensors etc and the diagnostic tools for sorting out the problems.
If you need a sensor etc let me know, can get costly having to buy them to find that wasnt the fault.
Carl
Posted 21st Nov 2009 at 03:41
carl.swan
trouble is the engine I have in now came with inlet with all sensors and injectors etc the only things common to both setups is wiring loom, injection relay, and fuel pump. I have had a diagnostic tool on it before when it was just a flat spot and it didnt detect anything thats why its making me think fuel pump or relay, may try it again now that its developed to complete failure see if i throws anything up.
8th 2008
14th 2007
Posted 21st Nov 2009 at 14:15
carl.swan
I think I will try another crank sensor and I'll see if i can coble together some sort of fuel pressure sensor (done it before on my race saxo using an old oil pressure gauge) got to recover the bloody thing as well asuming its still there or not on bricks.
8th 2008
14th 2007
Posted 21st Nov 2009 at 14:19
gti6girl
We had the same prob recentley and 1 off the plugs was snapped in half?
Posted 21st Nov 2009 at 15:15
