Author Subject: (EDIT) Idle issue, sorted now
spitfire
My car has got an idle issue.
It is hunting on idle (revs go up then drop then go up etc) also effects driving with it being a little irratic off powerSad
I'm going to clean the ICV (Stepper)
Also going to clean the Sensors but which ones and where are they? The PIC in the FAQ does not appear to be there.
How do you clean the sensors, I take it you have to un bolt them and them spary with carb cleaner?
Thanks guys.
If you aint first, your last!
Posted 25th Nov 2009 at 03:07
will130787
I had this issue with my rs turbo, needed a new lamba sensor?!
EDIT: It did it again 3 months later and a new coil pack sorted it out!
Ex Astor 6 owner Sad
Also an Ex owner of a Bianca 6 Sad
Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
Now driving Mk5 Golf GTTdi, mile muncher
But still live for the 306 Ninja
Posted 19th Nov 2009 at 17:10
spike_uk06
A good start to clean the ICV and the MAP sensor..
Humm the picture on here appears to be broken...
I just gave mine a good clean with a bit of WD40 on a rag....
EDIT. found it in another thread... Its clear where each one is... Sensor Locations
Team China
Team Pirelli
Team Cracked Bumper
92k
20th Nov 1999 she was born
Posted 19th Nov 2009 at 21:33
spitfire
Thanks for the help and finding that picture!
So do I have to un-bolt the sensors or just clean the connectors?
Posted 19th Nov 2009 at 23:41
paulchin
Odds on it's your ICV - just unplug it, then remove the two (Torx) screws holding it in. The part you can't see normally (as it's inside the manifold) will be gunked up with black stuff - clean all this off.
When you refit it, don't be too alarmed if the idle is all wrong - if theplunger has moved during the cleaning, it will need a bit of time to "reset". You can force the issue by disconnecting the battery -ve terminal for a couple of minutes - when I put my ICV back in, it wanted to idle at over 2,000 rpm until I pulled the -ve lead. After this, it was back to normal at 800 revs.
Hope this sorts it for you!
Posted 20th Nov 2009 at 01:35
petycf
is the 6 going to "reset" for a while when i change the MAP sensor, do i need to do the same thing as u did?
Posted 22nd Nov 2009 at 14:06
ballys16
Resetting the ECU after changing sensors isn't a bad idea at all.
XSi 8V -> S16
Posted 22nd Nov 2009 at 15:22
spitfire
Ended up taking car to mates to have it sorted.
ICV cleaned - sorted the hunting issue.
The Car was also put on a diagnostics machine, and uncovered issue with MAP sensor and O2 sensor. So these were replaced and the Throtle body was cleaned out too. All I can say is it made a huge difference car feels like it has a load more torque now!
Posted 25th Nov 2009 at 03:11
