Author Subject: Knocking when slowing down
jambo85
Hi all just picked up a new 6 today. Couple of issues i want advice on.
First it knocks when slowing down even when not braking. Also it vibrates when going above 70 which i think may be the tyre balance as braking is fine, but could it be my suspension? It has brand front springs.
Back to my phase 2 in black on the road.
Phase 3 sold after spending fortune on it.. It wont be missed.
AFTER a phase 3 tailgate in black and front bumper in ace condition.
Posted 18th Nov 2009 at 18:40
Most likely worn engine mounts allowing the engine to move too much causing the exhaust downpipe to hit the body, or a cracked chassis/engin top mount. Try dipping the clutch and braking, by removing the engine braking from the equation if the noise persists it must be something else. Possibly worn wishbones or ARB droplinks.
Posted 18th Nov 2009 at 18:51
russbez
id say drop links LOL
cheap to replace as well
again thats if engine isnt flopping about
My Rallye project thread
Posted 18th Nov 2009 at 19:01
jambo85
Cheers guys, any easy way of telling if mounts are done? If i best taking to garage and getting checked over?
Posted 18th Nov 2009 at 19:04
oecken
top mount is easy to check, you can just un screw the top will be cheaper to check it over yourself anyways!
See Here
Posted 18th Nov 2009 at 23:43
jambo85
See Here
being a complete noob in the engine department, what am i looking for to find out if it is this that is causing the problem?
i see in wellys guide how to check it but im not sure how i'll know if its fooked or not?
Posted 19th Nov 2009 at 02:14
jambo85
Worried now as noise does go away when clutch is down. This most likely mean my mount is damaged?
Also it makes the noise when i turn right but not left?
Got a bargin buy but now seeing why
Posted 20th Nov 2009 at 00:28
jambo85
Ah! The exhaust rattles under the centre console when i start the car! How much this gonna cost to repair! Should i be worried or is this common?
Posted 20th Nov 2009 at 00:51
