Author Subject: Gti6 wishbone ball joint pin dia
hainesygti6
Hi, I need some advice on something, I brought a hub from a seller on ebay specializing in Peugeot parts as it was labled up as a gti6 one, when I took the old one off to replace the hub I had been sent has a bigger sized hole that holds the lower arm to the hub. Just wanted to know what size hole the gti6 is as I think there is 2 sizes 16mm and 18mm?? Have I been sent a td one?
Refurbing Cyclones Black work in progress!
Phase 2 rear light conversion to go on.
Posted 14th Nov 2009 at 19:58
smighall
Smeg-all
16mm will be P1 and some early P2 cars, the rest were 18mm. Did you tell the seller which size you needed?
Meh
Posted 14th Nov 2009 at 20:32
d_p
interested on this, so what S reg have? 18mm i reckon? as the early ph2 is R reg
1998 GTi 6 - Black > Sold
Posted 14th Nov 2009 at 20:35
Best to measure it as there is no certain way of telling otherwise. Also be aware that the non-pas models had shorter ball joint carriers so they'll screw up the alignment.
I've been sold the non-pas ones before you see...
Posted 14th Nov 2009 at 22:06
barryrob78
Similar thing just happened to me too mate, bought a wishbone...wrong size emailed the seller to suggest describing which type he is selling ( i forget to ask lol)!
Ended up going to ECP for the correct ball joint size for my hub...which was 18mm btw and i have a 98 on an 's'.
AX GT-XR2I-205 MI16-VX220-S2000-RX8-A4 Quattro-GTI-6-Clio 172
Posted 14th Nov 2009 at 22:15
cress87
Be aware that the vast majority of people selling used vehicle parts on Ebay don't have a f*cking clue what they are selling most of the time. Yes
Posted 14th Nov 2009 at 22:37
hainesygti6
The thing is I won't mention any names but the seller I rather well known on here to so I was very surprised as the advert said phase1 gti6 hub which is exactly what I wanted but everybody makes mistakes.
Posted 15th Nov 2009 at 02:40
barryrob78
Think i can guess who you bought from hainsey...i used the same seller!
Sh*t happens though...lol
Posted 16th Nov 2009 at 20:42
hainesygti6
What was the outcome if you dont mind me asking barryrob?
Posted 16th Nov 2009 at 22:40
cress87
The vast majority don't know what they're selling. Could be a genuine mistake, especially if the hubs removed from the car weren't the originals. Yes
Posted 16th Nov 2009 at 22:45
hainesygti6
This is true but a good seller like them should have checked this first, Advert said "Phase 1 gti6 o/s hub" and if you say all the phase 1's are 16mm i thought i had no reason to doubt the seller.
Posted 16th Nov 2009 at 22:48
hainesygti6
Just add this little question will 16mm xsara vts hubs fit my 6?
Posted 16th Nov 2009 at 22:58
docwra
Ive just come across this as well - is there any way of telling without undoing the ball joint??
Interestingly ECP didnt mention it when I asked them but Peugeot UK did - I guess it because the ECP arms come with ball joints so its not an issue?
Ive got an R reg phase 2 GTI-6 BTW Smile
Lots of Nissans, two 306 GTI-6's. They are catching up! Big grin
Posted 20th Nov 2009 at 19:25
hainesygti6
Think the best thing is to hand over the reg of the car when ordering. Unless you buy second hand then your better to check to be safe. Dunno
Posted 20th Nov 2009 at 21:50
barryrob78
Sorry for late reply hainsey, i just bought the correct 18mm ball joint from ECP as the one i was sent was the wrong size and also had lots of upward/downward movement in it!
Couldn't be bothered waitin for it to be collected then delivered.
ECP were telling me it should be a 16mm hub though for my car!
Posted 20th Nov 2009 at 23:29
You guys aren't reading whats been written are you?
The reg won't tell you, ECP certainly can't tell you - only thing that will is to measure them. And measure both sides as well - they are french cars after all.
Posted 22nd Nov 2009 at 17:02
craigy_87
too true even peugeot told me the two different sizes, had to get both in the end and send one set back (thanks chris lol)
Posted 22nd Nov 2009 at 17:35
barryrob78
Thats correct adam, tis what i done and the only way to be 100% sure. Peugeot could tell you what the size is meant to be but you never know if the hubs have been changed at some point.
Posted 22nd Nov 2009 at 19:22
