Author Subject: Dash light bulbs
topshot_2k
Got a couple of issues,
1. My dipped headlight bulb on the dash cluster has stopped working completely (Main beam light works)
2. The odometer backlight sometime goes off and back on?
Should i change the bulbs if so which do i need and is it easy to do?
Are there any connections i need to check that may cause the problem?
Owner of a Nile Phase 2 GTI-6 & Impreza WRX Smile.
Posted 14th Nov 2009 at 03:00
Follow the heater matrix / dash removal FAQ for the speedo extraction. It's all straight forward.
You will then be faced with rear of the speedo and bulb access again simples.
If like the centre bulbs they can be tempremental so a good bump might make them stay on or not. Clean the contacts and just replace the bulbs, no need to buy the holders.
Posted 14th Nov 2009 at 05:50
topshot_2k
Thanks for your reply. Do youknow the type of bulb i need? are they the same as the clock/temp bulbs? My local pug dealer are useless Sad
Posted 15th Nov 2009 at 18:32
stegti6luvr
See Mick over at Crazy LED's for all your lighting needs... he's one of the best at what he does Wink
Posted 15th Nov 2009 at 20:47
