fixed my heaters and found out my aircon works
| Author | Subject: Squeeky brakes |
-sinden-
Senior User Location: RAMSGATE, KENT Registered: 15 May 2009 Posts: 506 Status: Offline |
My front o/s brake has started Squeeking. The disk and pads have got loads of life left. How do I stop it?________________________________________ fixed my heaters and found out my aircon works |
take it apart, clean them, put them back together.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cabbymeg
Regular Location: Alfreton/Derbyshite Registered: 04 Sep 2009 Posts: 323 Status: Offline |
Plus a bit of copper grease on the back of the pads just to be sure. Had to do that to mine on Sunday |
oecken
Seasoned Pro Location: Mt Cook, New Zealand Registered: 17 Feb 2009 Posts: 4,751 Status: Offline |
but may only be a temp fix, done this to mine, about 4 weeks later back to squeakyville ________________________________________ Ex-Black 6 - Speed has never killed anyone, suddenly becoming stationary... That's what gets you. |
si_man306
Seasoned Pro Location: Hertford Registered: 21 Apr 2005 Posts: 3,089 Status: Offline |
If you 'chamfer' the edges of the pad this tends to help. I'm pretty sure it's not pad-specific and it cured it on the lotus. Essentially you just sand an angle to the edge of the pad so the angle at which the edge meets the disc is no longer 90 degrees- if that makes any sense? It stops the resonance vibrations which are essentially causing the squeel.Pm me for more details- I had mine done for free during a routine service at a garage but very simple to do yourself- definitely re-copper grease anyway though as said before ![]() ________________________________________ "Rules are for the interpretation of wisemen and the obedience of fools" (Colin Chapman, Lotus founder) |
