displaying posts 1 to 2 of 2
Author Subject: speedo sensor
mike306
As I said in my introductory post, there is an issue with the speedo randomly deciding to stop working. It seems the most likely cause is the speedo pickup sensor/VSS.
When looking for a new one, I found 2 on ebay and am not sure which one to go for. Aparently one is electrical, the other electrical & mechanical
clicky1
clicky2
There's also one on GSF car parts, but doesn't specify what type it is...
Any ideas?
High boost '6 for weekends
406 2.1 Executive for weekdays
Posted 6th Nov 2009 at 04:12
either will do the trick, though obviously you dont need the one with a mechanical takeoff for the Speedo, only the S16 was like that AFAIK, all gti6's used the fully electronic setup.
as for the GSF one, doesn't matter if its cheaper, just bung the hole like they did in the factory before they used the fully electronic one.
Posted 6th Nov 2009 at 04:24
