Author Subject: Brake pedal adjustment
nealh
Hi chaps
Is it possible to adjust the height of the standard brake pedal upwards on a '6 (other than by buying a custom pedal box)?
I'd like to practice (and eventually use Big grin ) heel and toe gearchanges on track, but the current set up means the pedal is a bit low to blip the throttle once pressed down, other than with the top of your foot!
Neal
E39 M5
Ph2.5 GTI-6
Posted 4th Nov 2009 at 19:41
mxcrazy
It must be doable, i dont know if there is adjustment so to speak but you should be able to bend or cut and weld it, failing that, just make a spacer block from ally or something to bolt into the pedal, like platform shoes!!
I can heel and toe in mine as is, the only thing i have are braided brake lines, this might sharpen up the pedal/reduce travel due to less flex/bulge in the lines.
Its quite a thing to get right, keeping constant pressure whilst blipping a throttle is hard enough, let alone adjusting braking forces and blipping the throttle.
left foot braking is another area to look into, can make the car much more stable in a turn, keeps it balanced if doing it correctly.
Posted 4th Nov 2009 at 19:53
check that your accelerator cable isn't too tight.
Posted 4th Nov 2009 at 20:16
pedal blocks are the way forward. ran my engine in with these badboys behind the pedal LOL
Posted 5th Nov 2009 at 05:48
nealh
Thanks for the thoughts guys - pretty sure my accelerator pedal is correctly adjusted, but will check. Not sure I like the idea of pedal blocks...
E39 M5
Ph2.5 GTI-6
Posted 5th Nov 2009 at 14:11
dr-evil
Learnt to do it in my previous 6 - had to really syncro has reluctant on second - twas awkward due to the sharpness of the brakes.
Have to learn again once my ankles fixed - missing it so much Sad
Cad Monkey will work for chocolate biscuits....I'm not kidding
Posted 11th Nov 2009 at 00:15
