displaying posts 1 to 25 of 30
Author Subject: 205 GTI 6 Drive shaft question
antcla.85
My mate has a GTI powered 205, with a xsara gear box. He has had 3 sets of 1.9 new drive shafts, and they keep breaking. We have spoken to a well known 'peugeot performance specialist' who said we have to cut a few 'mm' out, to stop the breaking. Just wondered if anyone else has a 205 and if they have overcome a similar problem.
(EDITED POST, PROBLEM SOLVED)
Thanks
Ant
Life is short, make it interesting
Buy a Peugeot!
Posted 3rd Nov 2009 at 01:49
gman
Has the engine been tilted?
1992 Onyx Black 205 GTI-6
2005 Honda S2000 (Sold)
2002 Audi S3 (Sold)
2005 Clio 182 Trophy (sold)
Posted 3rd Nov 2009 at 01:03
gti6girl
yeah cut about 8mm off
We dont have any problems
Posted 3rd Nov 2009 at 01:07
Indeed you need to shorten the shaft Smile
Posted 3rd Nov 2009 at 01:11
mechanical_repairs
I have a xsara box in my gti6 205 and with xsara shafts its fine.
Can send you a couple if you need?
Carl
Prob solved then
Posted 3rd Nov 2009 at 01:13
gman
Carl, I assume you need to run the Xsara/306 hubs if yu run the vts shafts? Is there anything else you would need to change?
2002 Audi S3 (Sold)
Posted 3rd Nov 2009 at 01:20
Scrompy
Aka Quagmire83
Carl
Well yeah it will be fine parked up in a garage 365 days a year!
X-Box Live gamertag: Scrompy
PS3 tag: Scrompy
Posted 3rd Nov 2009 at 01:26
mechanical_repairs
Ah yes thats a good point, i run the 306/xsara hubs, other than that ie shockers and top mounts etc is all 205, i tried the 306 setup and it was a bit 4x4 like.
Have hubs aswell should you need them with either the 16mm ball joints or the later 18mm ones.
Been a while since i did the conversion now, call me if you like can have a chat about it.
Carl
You jealousRazz, its done i think 200 miles now, my mates car is a daily driver and runs the same setup.
Carl
Posted 3rd Nov 2009 at 01:29
Scrompy
Aka Quagmire83
Im not jelous, I have my own beast sat on the driveway that gets used! Razz
PS3 tag: Scrompy
Posted 3rd Nov 2009 at 01:31
gti6girl
quote:
who said we have to cut a few 'mm' out and weld it back together, to stop the breaking
Just re-read your post
Nobody told you to weld anything?
Also i have found out that you are not using pug shafts wich would explain your problem
cheers
Posted 3rd Nov 2009 at 01:35
gti6girl
you can also put the inner knuckle from a 6 shaft (n/s) on the end of you 205 shaft
saves you chopping anything
Posted 3rd Nov 2009 at 01:38
antcla.85
Ok thanks for the relpys. Carl, are we saying that to use xsara shafts we need to change the 205 hubs to the xsara ones? If so please could you quote for these parts?
Ant
Buy a Peugeot!
Posted 3rd Nov 2009 at 02:04
jonnie205
you need the xsara or gti6 inner cv cup and then a 205 shaft
Posted 3rd Nov 2009 at 01:41
allanallen
Carl
Do you mean your running the inner joints or have you shortened the shafts? Standard xsara shafts are far to long aren't they?!
16mm Xsara/306 hubs are virtually identical to 205 hubs so I don't see how this would help apart from possibly losing you some camber.
Facebook
Posted 3rd Nov 2009 at 01:42
gti6girl
ant - buy a genuine shaft and chop 8mm off or put a 6 end on the n/s shaft
job done
Posted 3rd Nov 2009 at 01:44
antcla.85
PROBLEM SOLVED CHEERS ALL FOR HELP
Buy a Peugeot!
Posted 3rd Nov 2009 at 01:48
gman
Thanks Carl, I think I'll get the engine and everything running first and see how I go. If I start breaking them I'll give you a shout.
2002 Audi S3 (Sold)
toby
If my memory serves me correctly we used to put 306 TD ends on a 205 shaft so they didn't bottom out in the diff, it was 15 years ago so i might be wrong!
Previous Peugeot - 2000(w)GTI-6, Me old China, Supercharged with working aircon!
Posted 3rd Nov 2009 at 04:07
yeah, that's the very same trick they mention abov,e use the later inner CV joint cup.
Posted 3rd Nov 2009 at 22:44
smighall
Smeg-all
Also 205 1.9 gti hubs are basically the same as the 16mm (balljoint) 306 ones, just without the ABS holes...
Meh
Posted 3rd Nov 2009 at 22:47
and less camber
Posted 3rd Nov 2009 at 22:52
baz306gti-6
Having issues with my 205 gti6 and it's drive shafts, I fitted a 16v XSI 5 speed to my gti6 lump and I have been using 1.9 205 Gti shafts, I have knackerd the outer passengers as the gaiter spilt on a 200 mile trip. I have a worn outer joint now Sad, right the only shafts I have are some 1.6 Gti ones or gti6 ones along with the 1.9 that are fitted. Any smart whizz know if I can make a decent set outer what I have, I know the standard gti6 shafts are to long but the sound of it I could swap some bits from each ?
Oh btw I run 309 Gti arms
Put your spare GTI6 lump a 205 GTI
Peugeot Expert 1.9D (69bhp Beast)
Peugeot 306 GTI6 £700 (For Sale)
1995 328 BMW coupe (blew it up)
1987 205 GTI6 (Now back on the road)
New 1991 Miami blue 205 Gti (sold)
........Good times Smile
Posted 13th Oct 2011 at 23:22
jonnie205
you need the gti6, xsi, ns inner cv cup
Posted 14th Oct 2011 at 09:17
gman
You can do what jonnie said, but if the safts eventally go or boots split, then it is a pain to start swapping the cups onto the replacement shaft.
I would use a 205 diff with the 306 box. That way you can still run the standard 309 shafts without the need to swap the cups over.
Edit: sorry, just realised you run 309 arms, so you would ideally need 309 shafts to eliminate the risk of them pulling out of the box on full lock.
2002 Audi S3 (Sold)
Posted 14th Oct 2011 at 10:18
