Author Subject: Throttle butterfly sticking.
toby
When at idle the butterfly seems to stick and once past this point it moves freely enough, all seems clean enough inside so are there any other ware points or issues that would cause this?
The throttle cable is free from resistance so it isn't that, I came back the other day after a little blat and it was stuck open a bit revving to 2-3000 rpm.
Any input greatly appreciated.
Previous Peugeot - 2000(w)GTI-6, Me old China, Supercharged with working aircon!
Posted 3rd Nov 2009 at 00:16
smegal
Is the spring attached properly?
Ex SC-6
Now in a Megane R26
Posted 3rd Nov 2009 at 00:19
toby
I'll check it again, when I looked it seemed to be giving resistance as though it was working but after feeling the tension on a throttle body belonging to a friends car his appeared to have more resistance and when it snapped shut there was no sticking point when trying to open it.
Posted 3rd Nov 2009 at 00:27
mechanical_repairs
I have had this before and never could see what was causing the problem, in the end i changed the throttle body for another. It was weird how it happened, the throttle when closed was a bugger to open and with some force opened but made you look like a very poor driverLOL
If you dont find the problem let me know and i can sort you a replacement.
Carl
Posted 3rd Nov 2009 at 01:36
ry
I had this when I bought an inlet manifold/TB from Sid who had the 2.1 'thing'.
It was the allen key screw that you could adjust on the TB which was too loose/kept adjusting itself. I just needed a brand new one and plenty of lubricant.
HTH
Turbocharged Honda Integra Type R DC2
Posted 3rd Nov 2009 at 03:10
toby
Yes that sounds exactly the same thing, i'll have a play with it to see if i can sort it but if not i'll givd you a call.
Carl
Posted 3rd Nov 2009 at 03:43
Denis
When the throttle stop screw is not adjusted correctly
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 3rd Nov 2009 at 04:48
stebro-gti-6
China Blue on Black Clones
Posted 3rd Nov 2009 at 21:52
toby
Thanks chaps, I know the item you're on about, I'll give it a go.
Posted 3rd Nov 2009 at 22:13
toby
Sorted it tonight, as said the screw needed adjusting but not because it had moved, its because when the throttle snaps shut it gradually deforms the plastic that holds the cable and causes the butterfly to close too far and get stuck. Thanks for the info it now feels a different car.
Posted 5th Nov 2009 at 04:52
vts_gav
any chance of a reference pic to know what you are on about?
Posted 6th Nov 2009 at 22:46
toby
I'll take one tomorrow when back at the residence.
Posted 7th Nov 2009 at 16:45
