| Author | Subject: 3.0 v6 conversion driving me mad |
boz_v6
Newbie Location: Truro Registered: 30 Oct 2009 Posts: 11 Status: Offline |
does anybody have any decent detail on the 306 3.0 v6 conversion i have the d8 engine and a good garage to do the work but because they are vw/audi specialists theve never done one help please |
You are getting a garage to do it?! Bloody hell...Have a good search and you should find a few things. ________________________________________ Nothing to see here |
boz_v6
i've looked everywhere but cnt get any solid detail ive got a rough idea of parts that need altering eg, downpipe,engine mounts,driveshafts but havent a clew on the loom or gear linkage |
Gear linkage you just use the 406 cable system.Driveshafts need to be created. Answer from welshpug gained from a search: yes it will fit, needs 2 custom mounts, gearbox one bolts straight on though. shortened 406 shafts, modified subframe, radiator to suit, fit the 406 cable shift system (easy jo ![]() sort the wiring, which is straightforward on the 194 bhp engine, PITA on the 210 engine as you need an aftermarket ECU. ________________________________________ Nothing to see here |
VW VR6 rad.________________________________________ Nothing to see here |
boz_v6
ideal that makes things alot clearer sounds easy when you put it that way cheers |
steve954
Seasoned Pro Location: norwich Registered: 16 Nov 2008 Posts: 2,213 Status: Offline |
lee306v6 has the conversion in his rallye could pm him for some info.________________________________________ stevie09 308 gt140 cc 03 octavia vrs IF IT AIN'T BROKE, IT AIN'T A GTI6 |
boz_v6
is that the rad off a golf vr6 or are they al the same |
I have seen that Hilgie changed to a 1.6 golf rad as they have a bleed point in them which the VR6 dont, otherwise they are the same size apparently.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
boz_v6
there is a mk3 golf vr6 rad on ebay will that do the job |
