Author Subject: gearbox problem.
fb_seven
ive got a gearbox problem i dont know where to start or how to explain this lol. but here goes.
when im driving along when i go into 1st and 2nd it goes halfway and stops and i gotta force it into gear and 3rd makes some sort of grinding noise but 4th 5th and 6th along with reverse is fine.
but when the car is stationary even with the engine running the gearbox feels fine well noway near as bad it goes straight into all the 3 gears.
Posted 29th Oct 2009 at 03:36
allanallen
Were is the clutch biting point? Right down at the bottom?
Facebook
Posted 29th Oct 2009 at 03:41
fb_seven
well i dont know lol. the clutch is so hard atm i cant feel the biting point.
Posted 29th Oct 2009 at 03:42
allanallen
I'd start by replacing the cable then. It sounds like the self adjuster isn't doing its job. You can adjust them up manually with the aid of an assistant though.
Facebook
Posted 29th Oct 2009 at 04:01
fb_seven
could the clutch effect the gears thats much?
Posted 29th Oct 2009 at 04:05
allanallen
If its not pulling the cable in enough it will be a bas**rd to get in gear. Thats why I asked if the biting point is at the bottom of the pedal travel, this points to the clutch cable needing adjusting. The cable should adjust the slack up itself but they dont always work that well.
Facebook
Posted 29th Oct 2009 at 04:19
Could be worn syncros in first and second gear.
Posted 29th Oct 2009 at 04:21
SteviePut
Could it be worn linkages??
Posted 30th Oct 2009 at 04:26
fb_seven
i really have not got a clue mate lol.
Posted 30th Oct 2009 at 11:54
spike_uk06
My money is on worn linkages. Or a fubard clutch cable...
Team China
Team Pirelli
Team Cracked Bumper
92k
20th Nov 1999 she was born
Posted 30th Oct 2009 at 23:17
fb_seven
i will get them both changed
Posted 30th Oct 2009 at 23:42
mechanical_repairs
If the clutch is very hard and stiff to operate i would say you need to get this checked over first, i think that will more than likely be your fault.
Carl
Posted 31st Oct 2009 at 03:16
cwspellowe
I'll second the clutch cable as your first point of call.
Replaced mine for an OEM one last weekend, clutch is much lighter and there's no resistance in gear changes now.
Bye bye Sundance Kid Sad
Posted 31st Oct 2009 at 03:29
lower engine or gearbox mounts?
Posted 31st Oct 2009 at 04:52
fb_seven
ive only had the car about 3 weeks, i ent done nothing yet lol. i wanted to get it all done at once.
Posted 31st Oct 2009 at 11:54
