displaying posts 1 to 2 of 2
Author Subject: Valve springs information
ecureuil_zx16v
I'm needing a important information about XU10J4RS valve springs. Will now use solid lifters and change valve springs
I will put some useful informations about valve springs and retainers, and need other
External valve spring
ext diameter - 27.4mm
int diameter - 19.9mm
decompressed height - 48.6mm
Internal valve spring
ext diameter - 18.5mm
int diameter - 13.45mm
decompressed height - 38.6mm
retainer - valve seats
for internal valve - 13.3 to 19.3
for external valve - 19.3 to 28.2
Found solid lifters with 32mm of diameter, OEM parts from a car... if somebody wants more info, MP-me
Informations I need:
- What's the installed spring height for this engine?
- Who knows the information of load/height for the OEM springs?
- Can I trust in using the OEM retainers for high load springs, such as 300lbs springs?
- what brands make special valve springs for this head?
Citroen ZX 16v
XU10J4RS turbo
Posted 28th Oct 2009 at 03:51
someone like QEP or Sandy Brown could answer your questions Smile
Posted 28th Oct 2009 at 04:08
